'89 YZ250 questionsThis is a discussion on '89 YZ250 questions within the 2-Stroke Motorcycles - Yamaha forum, part of the 2-Stroke Motorcycle Forums category; [Only registered and activated users can see links. ]
I do not like their website, does not have hardly any ... |
#41
#42
| they list it for $50 but dont show a picture and they are out of stock...and are out of stock on98% of all pipe guards they carry. |
#43
| It definately shows a picture of my pipe guard...and says that it is only 32 dollars and some change. I would just get one of their catalogs unless u need it right now. Ryan |
#44
#45
| my friend started out with an 89 yz250. he did some tricks listed in eric gorr's book for it. he drilled out some sub ports. his bike would scream. it turned out to be a rocket |
#46
| Yardpro393, what ports did he drill out? I am going to got to that website and see what it says......u just seriously sparked my curiosity. Ryan |
#47
| eric gorr book? Do they have it at Boarders? Where can I obtain a copy? |
#48
#49
| Cool! Thanks! Anyone have the powernow mod pdf ? I can't seem to find a working link for the file. |
#50
| They have Gorr's book at boarders. $24.95. I read about drilling a 1/2" hole somewhere opposite of some port for that mod..increases low end power. But it doesn't go into detail or show any pictures of it. Sounds like a good tip but kinda useless if they show how to do it or give any further detail. |
#51
| Someone told me to saw off the rubber triangular protrusions from the reed block spacer. Has anyone done this mod and if so, what difference did it make? |
#52
| it has the pics and shows you where |
#53
| On what page? which picture? Because it wasn't on the page describing the hp-up tips for the 88-89 YZ's..unless I missed something. |
#54
| Hey, I have an 88 YZ250. The mid range sucks. It might have something to do with half the float missing. The book said poor mid range performance could be from improper fuel level. I need a good carb. Anyoney have one?? (cheap) My brother-in-law has an 85 CR250 (over bored to about 305) and the mid range is so much smoother. That's when I realized I did have a problem with my bike. The pin that hold the float in place is stuck for some reason. It will not come out. So I can't just change the float. The carb inlet as about 62mm and the outlet is about 62.5mm outer diameter. |
#55
| They retail for $412.00. I need one too. Bidding on one now on ebay, up to $55.00. I'm not going any higher. I know another guy who has one for $75. I may just buy a whole other bike for the parts I need cause this nickle and dime stuff is killing my wallet! |
#56
| You could buy pretty much any 2-stroke carb and fit it up, most are interchangeable and you could gain some power. |
#57
| I believe the correct size for this bike is 36mm. |
#58
| MY BAD...it's 38mm. Sorry. 89 YZ250 Mikuni model #TM38SS I.D. Mark 3JE00 Main Jet 340 Pilot Jet 60 Jet Needle 6DJ8-63 Needle clip position 3rd groove Needle Jet R-1 Slide Cutaway 4.0 Starter Jet 80 |
#59
| Yes I know about the nickle and dime thing. That's what it's been since I got my YZ250. (at about $700 for now) (not bad) Then I had to get an XR80 for one of the kids, and I still don't have that working yet. My other bike is two older bikes made into to one. 1976 YZ125, had a rusted engine, had a 71 CT1 175 trail/enduro that didn't work to well off road, so I pute the 175 on the YZ125, and now I have a YZ175, 71/76 hybread. LOL I've been searching other than the proper carb for my bike. Maybe one day on e-bay, I'll find the perfect one. Then I still need a new chain. Yata Yata Yata, Nickle and Dime, Nickle and Dime. It might not be so bad if I had a place to ride without traveling 2 hours. Just noticed I pute the wrong number on the measurement on my first post. I guess the proper numbers are 38mm inner diameter on the reed side, and about 54mm inner diameter on the filter side. |
#60
| Does anyone know if a 1990 YZ250 engine will bolt into a 1989 bike. Thanks. |
| 01 yz250 jetting problems/questions | hatch-attack | 2-Stroke Motorcycles - Yamaha | 4 | 10-14-2008 10:18 PM |
| 1989 yz250 suspension questions | bitshifter | 2-Stroke Motorcycles - Yamaha | 0 | 12-02-2007 12:29 PM |
| Questions, questions... | spartanbiker_117 | 2-Stroke Motorcycles - Honda | 12 | 08-18-2007 01:38 PM |
| yz250 questions? | p.e.z. | 2-Stroke Motorcycles - Yamaha | 4 | 07-24-2007 08:36 AM |
| New, used YZ250 questions (long, sorry) | HeavyD | 2-Stroke Motorcycles - Yamaha | 5 | 12-10-2004 03:43 PM |
