All Things Moto! Web Forums
82 YZ490 throttle stuck full open
This is a discussion on 82 YZ490 throttle stuck full open within the 2-Stroke Motorcycles - Yamaha forum, part of the 2-Stroke Motorcycle Forums category; Not sure what happened, I was riding the track, just took a turn, and then all of a sudden, without ...
Old 07-05-2009, 01:09 AM
mkpack77's Avatar
Last Online: 10-13-2009 12:33 AM
Usflag 82 YZ490 throttle stuck full open
Not sure what happened, I was riding the track, just took a turn, and then all of a sudden, without even touching the throttle, the engine just completely rev'd out. It stays wide open, regardless of what position the throttle is in, I'm fairly sure the slide is working properly because when I twist the throttle I can hear the slide. I had to throw it into a high gear in order to stall it, and if I re-start it, it goes right back to full open. Any ideas on the cause of this, I don't want to tear it apart until I get some tips. thanks
Old 07-06-2009, 07:16 PM
Last Online: 09-21-2009 07:38 PM
Exclamation
I sent private message.But i'd say yr main jet unscrewed itself or the needle came out of its hole or the circlip came off.Any way you should tear down the carb before riding her again... I wouldnt want my 490 going without my permission on the best day!!!!
Old 07-07-2009, 08:39 AM
departed for parts unknown
Last Online: 10-24-2009 11:22 AM
My 465 did that occasionally.Crank seals fixed it.Leak it down and check for leaks.
Old 07-07-2009, 05:57 PM
Thats true It probably wouldnt run wide open with jet problems.More like full choke. Sounds more like an air leak.
Old 07-07-2009, 07:52 PM
Yz 125
Last Online: 07-23-2009 11:28 AM
nothing wrong with wide open hahaha
i hope you get it fixed !
Old 07-07-2009, 11:27 PM
mkpack77's Avatar
how would i go about checking it for leaks? how hard of a task is it to change them? don't i have to "bake" the halves in the oven to change them???
Old 07-08-2009, 02:08 PM
your manual has detailed instructions on pressure testing the crank case.
Old 07-08-2009, 03:08 PM
VAL's Avatar
VAL VAL is offline
Get your motor runnin
Last Online: Yesterday 05:32 PM
Could have been it ran out of gas. Just before a two stoke runs completely out of gas, it will rev to the moon because of an excessive lean condition. (Running out of gas is about as lean as you can get.) A restricked fuel filter or a stuck float valve can do it as well. I would at least go through the fuel system to see.
Main seals are easy, no baking needed. Look around you intake as well.
How many times did you have to put your chonies through the wash to get that stain out after this happened?
Old 07-09-2009, 12:54 AM
mkpack77's Avatar
yeah i had to wash them quite a few times, luckily it was right before a jump so i had enough time to react.
it's not out of fuel, i'm hoping it's something obvious in the carb but i guess the crank seals won't be that bad. does anyone know of a carb rebuild kit; do they even make em?? the only place i know of to get carb parts is off of the oem yam. site
does anyone know where i can get crank seals from? i know i've seen em on a site somewhere but i can't find it now.
oh and d tom, i didn't get your message????
Old 07-31-2009, 05:55 PM
Last Online: 08-05-2009 05:31 PM
Yours does sound like an air leak as if it was a slide sticking then even throwing a higher gear at it would not really stop it, if it is running lean due to an air leak then the power it delivers during the revving out is not that great? if it feels very torquey then suspect carb slide sticking, if not then suspect an air leak after carb or crank seals, pressure test the cylinder to see if the main seals or casing is leaking.
Oh and I had a slide stick on my last outing due to me not running a carb top boot and it filled up with dirt and it stuck about half open just as I wanted to brake and I couldnt stall the engine with full rear brake on! luckily it released just as I bounced over the track side into a field! scary!
Old 08-02-2009, 02:31 PM
Last Online: 08-05-2009 03:32 PM
Default crankseals...
crank seals is to a yz490 is hard to find IF you dont know that yz250 has the same seals from -76 to -87....which is more common......
check out partnumbers if you like.....
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads for: 82 YZ490 throttle stuck full open
01 kx250 starts but stuck wide open TeamGreen2323 2-Stroke Motorcycles - Kawasaki 6 07-03-2007 12:25 PM
CRF 450 Sputtering at full throttle....HELP strykmaster 4-Stroke Motorcycles - Honda 23 02-03-2006 06:30 PM
Stuck throttle 660 4 stroke HELP Dick Stevens Misc Riding Types 0 02-03-2005 03:42 PM
Yamaha 250F Full Throttle Start zebramask70 4-Stroke Motorcycles - Yamaha 5 10-03-2004 05:46 PM
Stuck Throttle - Need Help CR Kevin General Discussion 16 09-22-2004 08:58 PM
vB.Sponsors
