Old 10-01-2017, 04:07 PM
Last Online: 10-01-2017 04:07 PM
Default 79 yamaha IT 175 no spark
i bought a 79 IT 175 that was not running. it has no spark and i was told that it need a magneto. before i buy one i want to test it and make sure its bad. i cant find anywhere online where it lists which wires to test and what their readings should be. does anybody here know? the mag has 5 wires and the CDI has 7. thanks in advance
Old 10-02-2017, 11:37 AM
Do an OHMs test of the coil. Clean the coil mounts of rust and dirt.
Old 05-31-2018, 11:37 PM
Last Online: 10-19-2018 01:47 PM
Troubleshooting the Ignition System
Always try a new spark plug with a correct spark gap before doing anything else.
Testing for spark:
Remove the spark plug and connect it to the spark plug cap. Manually hold the spark plug with cloth onto the cylinder head (metal to metal) and make sure the side electrode is sideways so you can see the spark gap clearly. Kick over the engine to see if any spark is generated. It is hard to see in full daylight so it's best to do at night or inside. If no spark happens then there is a problem. If you have spark but the engine won't start then one of these problems exist:
1. Compression is being lost due to loose head nuts or leaking head gasket.
2. Something is really wrong with the carburetor such as a pilot jet being clogged or an intake air leak (possibly at the crank seals).
3. The ignition system is too weak for the engines compression ratio. Ignition magnetos normally weaken over decades and then won't create enough voltage when kicking over the engine.
If the engine has a high compression ratio it requires a very strong ignition system (for high spark voltage). If the ignition is weak then it can spark in free air but not in the compressed air inside the engine. You can try lessening the spark gap so a spark can happen with the low spark voltage.
Test the Stator Coil:
Use an AC voltmeter to test for 25-50 volts coming out of the stator coil as you kick the engine over with the spark plug removed. First disconnect the stator coil wires from the CDI. I prefer using an analog voltmeter such as this one: [voltmeter] If the voltage is there then the stator coil is OK. But some stator coils provide ground to the CDI by its clean metal-to-metal connection to the cases. Good metal to metal contact there is essential. A loose or rusty connection there creates resistance which lessens spark strength.
Test the CDI:
You can test for total circuit performance (without determining the peak output voltage which requires a special test circuit or a meter that can read peak voltage) by just holding the CDI output wires while kicking over the engine. Someone may have to help you with that. Start out very slow and gradually kick faster till you feel a minor shock. I prefer this basic method because the output voltage lasts for only a few thousandths of a second which most meters can't register. If you are getting shocked then suspect the high voltage coil or the spark plug cap or the spark plug as bad.
You can't test for resistance at the input or output of the CDI because the input is a combo of resistance and a diode, and the output is capacitance and a diode.
What normally goes bad in a CDI is one of the diodes, the SCR (black transistor with 3 legs), and the large output capacitor (the largest component on the board). Unfortunately the circuit components are buried in epoxy and impossible to get to.
Similar Threads for: 79 yamaha IT 175 no spark
1972 yamaha 100 Enduro no spark? bpackham 2-Stroke Dirt Bikes - Yamaha 2 03-01-2013 10:03 PM
PW80, Yamaha, no spark Vince 69 2-Stroke Dirt Bikes - Yamaha 1 06-29-2012 10:03 AM
2000 yamaha warrior almost no spark thriller ATV/UTV - Yamaha 5 05-10-2011 09:31 PM
Yamaha Blaster Spark sometimes Yamahablaster1989 2-Stroke Dirt Bike Forums 0 01-27-2010 07:16 PM
1974 Yamaha DT175 no spark Shadow175 2-Stroke Dirt Bikes - Yamaha 0 05-05-2009 09:00 PM
