50 cc yahamaThis is a discussion on 50 cc yahama within the 2-Stroke Motorcycles - Yamaha forum, part of the 2-Stroke Motorcycle Forums category; carb is clean ,reeds seem to be ok,plug is firing there is compression,
it seems like there isn't getting any ... |
| carb is clean ,reeds seem to be ok,plug is firing there is compression, it seems like there isn't getting any gas to the cylinder but there are small drops of gas coming from the exaust it won't fire even with starting fluid in the carb can anyone help steve |
| Did you make sure that on the throttle the switch is set on "start" not "run"? If it is on run the bike will not generate enough spark to get it going. Also check your choke cable to make sure its not stuck. Im willing to bet its one of those two things. Welcome to ATM also!! |
| 2000 yahama warrior help | vingen | ATV/UTV - Yamaha | 3 | 10-16-2008 09:10 PM |
| YAHAMA TICK | teg | ATV/UTV - Yamaha | 3 | 09-21-2003 03:16 PM |
