2005 YZ 250 Off Set Triple ClampsThis is a discussion on 2005 YZ 250 Off Set Triple Clamps within the 2-Stroke Motorcycles - Yamaha forum, part of the 2-Stroke Motorcycle Forums category; Just wanted to know if anyone was using offset triple clamps for their 05 YZ's?... |
| Just wanted to know if anyone was using offset triple clamps for their 05 YZ's? |
| I am on my 250. It makes it turn alot better. 125 is stock though. |
| I know Satch has aftermarket triples but I can't remember if they are offset or not. Maybe he will chime in and let you know. |
| thank you for the introduction Keeto.... All I did was change out the top clamp to run Pro Tapers (the only bar to run BTW). I am so happy with the way the bike turns now.....I don't have any reason to change the offset. Of course 756's graced the front end before I ever rode the bike |
| My answer to your question is no I haven't. The frame geometry is the same for the 05 as it is for my 04. Like Satch, all I changed was the top clamp so I could fit my Pro Tapers. It turns SWEEEEEEEEEEEEEET. |
| Bit Off-Topic, but does anyone have experience with the TAG Matrix triple clamp? Thanks in advance. |
| Thanks for all the posts. I'm not thrilled with how it turns and and was looking for some solutions. Though I rode the new bike without setting the sag, adjusting the suspension for my weight, etc... I raised the forks slightly and am going to set everything for next time to see if that helps. I put a set of RG3 20 mm offest clamps on my 04' CRF 450 and that made a big difference. I've heard people complaining about the front end 'push' on the 05' YZ 250, so I just wanted to see what people were up to. thanks. |
| I have stiffer springs front/rear and I raised my forks 10mm in the clamps and have my sag set at 95mm. The thing still hits the inside lines or will cut in the middle of a corner without any problems. |
| Ok, what front tire do you recommend then? |
| The Dunlop D756 is supposed to work good in many conditions, but I've never used it. I do like the Michelin StarCross MS3 tires though. They wear great and hook-up much better than the D739. |
| I've got a 742 on the front of mine. Works pretty good. I've used 756's in the past. They are good too. Anything is better than the 739. |
| Top Triple clamps | konaman | 4-Stroke Motorcycles - General Discussion | 4 | 03-05-2008 08:17 AM |
| WTB CR/CRF Triple Clamps | Caseys500 | Wanted Items | 6 | 12-13-2007 05:06 PM |
| Triple clamps? | rev440x | Motorcycle Suspension Tuning | 19 | 05-15-2004 10:54 PM |
| What do triple clamps do | Jason | General Discussion | 32 | 12-12-2003 10:21 AM |
| triple clamps????? | reborn_450 | 4-Stroke Motorcycles - General Discussion | 24 | 09-05-2003 03:40 AM |
