Old 07-28-2017, 06:40 PM
Last Online: 08-08-2017 01:15 PM
Default 2004 YZ125 oil pump leaking oil
I have a YZ125 and there is oil leaking out around the oil pump and hose to the radiator and I don't know why, it seems to be coming from different areas. Does anybody know how to fix this?
Old 07-28-2017, 08:53 PM
Last Online: Today 01:25 PM
There is not an oil pump on a YZ125. There is a water pump on the clutch side of the engine.
Maybe that is what you are talking about.
Old 08-08-2017, 01:14 PM
No I've been told multiple times that there is an oil pump and It's at the top of the cylinder and has a tube running down the side of the frame that's connected to it as if it were an overflow but I'm thinking of just taking it to a shop but it's seems to be coming out in multiple places in the crankcase too
Old 08-08-2017, 01:55 PM
bjunior's Avatar
novice
Last Online: Today 01:23 AM
hi it was said before 2 stroke don't have an oil pump. if u are having this much trouble with something simple u do not have a manual u need one. if its a 2 stroke or u are wrong on what type of bike it is? good luck
Old 08-08-2017, 02:06 PM
It sounds like what you are describing is the vent from the exhaust power valves.
Again, there is no fuel pump and whom ever has told you this does not know enough to tell anyone any thing about a YZ 2 stroke.
The other possibility is that what you have is not a YZ125 , but rather a cross country version with an oil injection pump that puts oil directly into the fuel mix rather than having to premix you fuel oil.
So, is it a YZ 125 or something else?
Old 08-09-2017, 09:30 AM
Last Online: 02-15-2018 05:39 PM
You've been told wrong multiple times then. 2 strokes do not use an oil pump, unless they are oil injected as PawPaw explained in his last post.
Old 09-13-2017, 05:34 PM
Last Online: 09-14-2017 05:58 AM
Do you mean oil coming from out of the powervalve hose? this is normal
Tags
2 stroke, oil, oil pump, yz125
Similar Threads for: 2004 YZ125 oil pump leaking oil
Water pump leaking Texas_rebel 2-Stroke Dirt Bikes - Honda 6 08-18-2014 07:28 PM
corroded water pump leaking in to clutch case EASY FIX honda rider 979 2-Stroke Dirt Bike Forums 1 05-30-2013 11:44 PM
89 CR250R leaking water pump krzywhiteboy 2-Stroke Dirt Bikes - Honda 6 10-15-2007 08:19 AM
250F leaking water from bottom of water pump lsqrus 4-Stroke Dirt Bikes - Yamaha 2 09-09-2007 01:05 AM
CRF450 leaking water pump seal question pjmenez 4-Stroke Dirt Bikes - Honda 11 09-07-2007 09:00 AM
