Old 01-24-2019, 06:00 AM
Last Online: 03-12-2019 08:13 PM
Default 2003 yz125 throttle valve
Throttle valve has a chip in it. Yamaha OEM 160.00, I heard I could use one out of a 04 or newer cr125r 60.00 dollars. Does anyone have information about this. Cut away on mine is 4.0 and for what I'm seeing Honda is same.
Old 01-24-2019, 08:17 AM
Last Online: 06-30-2020 11:30 AM
As long as it's the same make/model of carb (IE Kiehin PWK, Mikuni TMX etc) it will be fine.
Old 01-26-2019, 10:07 AM
Yamaha slide cut is 4.0 Honda is 4.5. Will that effect much and how would I adjust to it? Thanks
Old 01-28-2019, 08:18 AM
You could modify the 4.0 to 4.5 if you can find the spec. May not be necessary though, the cutaway only affects idle/off idle response if I'm not mistaken. 4.0 would be slightly leaner than 4.5. Here's a great article explaining things in depth- Safely Jetting your two stroke dirt bike. - KX Guru Racing
Similar Threads for: 2003 yz125 throttle valve
2003 CR250 clacking noise at 2/3s RPM with constant throttle kportingale 2-Stroke Dirt Bikes - Honda 2 03-06-2011 09:41 AM
2003 cr125 running rich at 1/2 to full throttle Luckyduck272 2-Stroke Dirt Bikes - Honda 1 01-28-2010 08:55 PM
Throttle valve spring DR125 Ks Dad 4-Stroke Dirt Bikes - Suzuki 0 10-15-2008 11:18 AM
YZSKY.. (Husky CR125/Yamaha YZ125 crossbreed) won't rev past 3/4 throttle Jethro 2-Stroke Dirt Bike Forums 50 12-27-2007 11:42 AM
Yz125 wont pull after half throttle after new FMF Rev pipe... cougar207 2-Stroke Dirt Bikes - Yamaha 3 04-11-2007 11:53 PM
