Old 09-04-2017, 08:10 PM
Last Online: 09-05-2017 07:45 PM
Default 2002 yz125 radiator fluid question
hey everyone so i have a question recently just rebuilt the top end on my bike got it all back together. the bike startd up in 3 kicks i have some carb issues but ill save that for another post. so the next day i went out to the garage to see a puddle of radiator fluid and noticed it was coming from one of the carb hoses. ive read a few places it could be one of the gaskets that are bad or didnt seat right?? so any advice where to start? thanks guys
Old 09-04-2017, 08:50 PM
Most likely a bad head gasket. You can do a leak test to be sure.
Old 09-05-2017, 07:29 AM
wFo250's Avatar
will fall over
Last Online: 05-12-2021 11:54 AM
If its coming from the carb, it's fuel not fluid. Double check what it is, and from where it is coming.
Old 09-05-2017, 11:06 AM
Last Online: 11-17-2021 07:05 PM
I doubt that coolant is coming from a carb hose. It is possible, and if it really is, the crankcase and pipe will be full of coolant too. Like stated above, double check the "what" and "where from".
Old 09-05-2017, 05:35 PM
so i double checked and it seemed to be coming from the breather vent line from the power valve cover. so is this normal?
Old 09-05-2017, 09:21 PM
wFo250's Avatar
will fall over
Yep. your assembly must be clean if it isn't dripping black. What are you using for coolant?
Old 09-13-2017, 05:26 PM
Last Online: 09-14-2017 05:58 AM
Usually that breather tube lets out excess oil
Similar Threads for: 2002 yz125 radiator fluid question
2002 YZ125 engine question 1st_yz125 2-Stroke Dirt Bikes - Yamaha 0 12-10-2015 08:40 PM
06 YZ 450 losing radiator fluid after 1 ride Smokinjoe35 General Discussion 3 12-12-2010 06:29 PM
yz125 transmission fluid giffy 2-Stroke Dirt Bikes - Yamaha 2 08-18-2010 07:53 AM
leaking radiator fluid motocrossjake12 4-Stroke Dirt Bikes - Yamaha 15 12-13-2008 12:01 AM
2002 yz125 question yz125-Racer-5 2-Stroke Dirt Bikes - Yamaha 3 08-07-2008 10:31 AM
