2002 YZ 250 Fork oil?This is a discussion on 2002 YZ 250 Fork oil? within the 2-Stroke Motorcycles - Yamaha forum, part of the 2-Stroke Motorcycle Forums category; Hi, I have a question about fork oil..I'm used to seeing 5w, 10w..etc..but the manual for my '02 YZ250 says ... |
| Hi, I have a question about fork oil..I'm used to seeing 5w, 10w..etc..but the manual for my '02 YZ250 says to use "01" oil??? Whats that? Is there an equvalent? Any help would be great...Thanks |
| Welcome to ATM, sorry I'm not an oil expert I just buy the fork oil on the shelf at the dealer. |
| Ya thats what I'm thinking...I just want to make sure, I mean they don't say to use ONLY that oild for no reason...I'll have to call the dealer. Thanks |
| Fork oil is formulated for that specific application. The weight is not the only factor, there are additives that give the oil qualities to do what it is supposed to do. Send a PM to shocknut, he will be able to explain the differences in fork oil. |
| Re: 2002 YZ 250 Fork oil? Ya I realize that, Thanks |
| I haven't recieved a reply from shocknut yet. But the local dealer said that is the same as 3w. The Yamaha "01" oils is just too expensive. Thanks for the help |
| ya can use 5wt or ATF, Auto Transmission Fluid |
| The difference in the fork oils is "weight" or in other terms the thickness. The thicker the oil the slower it flows through the same size valving. This affects both rebound and compression. I think the manufacturers use something around 5 or 8 weight in most forks today. |
| Right side fork really bouncy after changing my fork seals. | jrhockey03 | Motorcycle Suspension Tuning | 2 | 05-07-2009 06:31 AM |
| 2003 kx 250 fork oil and fork seal service | wera917 | Motorcycle Suspension Tuning | 4 | 02-04-2007 09:26 PM |
| 2002 yz 125 | ditman22 | Motorcycles & ATV's | 2 | 10-22-2006 06:49 PM |
| 01 CR250 fork protector rubbing on fork tube | AustoUS | 2-Stroke Motorcycles - Honda | 15 | 08-26-2006 03:30 PM |
