2002 yz 125 Head ShakeThis is a discussion on 2002 yz 125 Head Shake within the 2-Stroke Motorcycles - Yamaha forum, part of the 2-Stroke Motorcycle Forums category; Anyone know how to reduce head shake without buying a steering damper. I was thinking of tightening the steering yoke ... |
| Anyone know how to reduce head shake without buying a steering damper. I was thinking of tightening the steering yoke and see if that made a difference? Any help would be appreciated. |
| First thing is to make sure you have your suspension set up properly. Do you have your sag set at 100-110mm? 100 seems to work best on these bikes. If your sag is set properly, try sliding your forks down in the triple clamps about 4-8mm. Try this first. I am betting it's your sag that is causing the problem. here is a helpful thread Setting Sag questions |
| Thanks Satch. I set my sag at 105mm and the fork tubes have about 2mm above my RG3 triple clamps. Do you think I should try lowering the tubes even further? |
| once you get a good balanced set up, then i would play with the height...depending on the track... |
| I also had head shake on my 2002 YZ134. Rick7331 and I cured it by lubing the steering stem bearings and then tightening everything down to torque spec. |
| If your rear spring were to stiff for you and your fork springs to soft the headshake would be persistant even with correct, sag and fork set up. |
| I'll lube and torque the steering tube as well as change the fork oil next and see if that changes anything. |
| my 2001 yz125 had really bad head shake turns out the bushings in the forks were bad also a bent axle and i neened new bearings cuz the bent axle |
| Head shake | Geoff | 4-Stroke Motorcycles - KTM | 2 | 05-27-2008 08:57 PM |
| Head shake baddddddddddddddd HELP | RMudslinger 250 | 2-Stroke Motorcycles - Suzuki | 6 | 10-09-2007 12:35 AM |
| 2001 RM head shake | hardlydangerous | Motorcycle Suspension Tuning | 4 | 04-24-2005 01:20 PM |
| Head Shake? How to correct? | brcrk | General Discussion | 27 | 10-15-2004 03:20 PM |
| Head shake | yamaha250F | 4-Stroke Motorcycles - Yamaha | 25 | 02-05-2003 05:48 PM |
