2001 Yz 125 clutch and throttle problems.This is a discussion on 2001 Yz 125 clutch and throttle problems. within the 2-Stroke Dirt Bike - Yamaha forum, part of the 2-Stroke Dirt Bike Forums category; Hello I am a 16 year old who just got his first motocross bike! i had it for all of ... |
| Hello I am a 16 year old who just got his first motocross bike! i had it for all of 40 hours and the motor exploded Help! What do I do? The bike does not stall when I switch gears with clutch in (good) does not completely disengage when clutch handle is completely out. (Bad) Now for the throttle: i have the bike almost completely turned to the left and it races because the cable is being pinched. Turn to the right it id fine. i just need to know the exact path it is supposed take. feel free to call me with some tips! 1203 448 8456 or email [Only registered and activated users can see links. ] thanks, sean9224 |
| The throttle cable routing goes from the twist grip to the frame by the steering stem, then along the right side of the frame rail under the tank to the carb. Make sure when you put the tank on that the front mounting brackets do not catch the cable and push it under the frame rail. The clutch could be any number of things but the first that comes to mind is the adjuster on the handle bar clutch lever or the in line (on the cable near the actuation lever) are out of adjustment. - How did the clutch work before the rebuild? - Is the adjuster on the handle bar all the way in or out? |
and the clutch did work before the re build but it jumped even if the cluch handle was fully retracted. and the adjuster by the clutch is fully in. |
| My YZ125 jumped a tad when I put it into gear. Other than the jumping did it run ok? Try backing out the adjuster at the clutch lever a little bit at a time. From what you are describing am I correctly believing the clutch is slipping when in motion? |
i am going to see if i have the correct length of cable. does your cable go from the left handle bar to the right side of the bike. and does your throttle cable go from the right side of the bike to the left? |
| I haven't had the 125 for a couple years now but I want to say the clutch cable went in front of the steering stem and then along the right side of the frame under the tank and then down to the actuating lever. The o/a length adjustment of the clutch cable could make a difference but unless it got changed or readjusted during the rebuild it should be ok. Were new clutch plates installed during the rebuild? I remember the throttle cable routed as I described in the above post. Check your manual and it will show the proper routing. |
i think it is the length of the cable as for the throttle i believe i miss routed it! ill get back to you if i need more help thank you i am going to check everything right now. |
Similar Threads for: 2001 Yz 125 clutch and throttle problems. | ||||
| 2001 Kx125 Problems | jc6711 | 2-Stroke Dirt Bike - Kawasaki | 3 | 07-12-2008 11:55 PM |
| kx 250 2001 power problems? | joey_2k6 | 2-Stroke Dirt Bike - Kawasaki | 0 | 04-02-2008 09:46 AM |
| Cleaning throttle or clutch cables? | pjg351 | Product Reviews | 9 | 11-06-2007 10:51 AM |
| 2001 KX 125 Running Problems.... | 01KX125Ryder | 2-Stroke Dirt Bike - Kawasaki | 10 | 03-02-2007 11:52 AM |
| throttle cable problems! | 1kx100 | 2-Stroke Dirt Bike - Yamaha | 2 | 12-21-2004 11:27 PM |
