2000 yz 125 tranny oil changeThis is a discussion on 2000 yz 125 tranny oil change within the 2-Stroke Dirt Bike - Yamaha forum, part of the 2-Stroke Dirt Bike Forums category; sorry for joining and just asking somewhat dumb questions. but i like this forum better than others. k what kind ... |
| sorry for joining and just asking somewhat dumb questions. but i like this forum better than others. k what kind of oil do i use to put in the gears cause i havent changed the oil ever. also one day i went riding and my bike took a huge chunk of meat outa my freinds leg and when i whent to get a ambulance i was on the top of all the gears, and now my bike like spits and sputters and wont even pop a whellie, and my dad said it was the jeting. and i need a new one so......... ne suggestions will be great! [FONT="Times New Roman"] |
| Man, an oil post first off. Get ready for a flood of opinions on this one. I'd look for a dirt in the carburetor for the bad running and set the float level so you can jet properly as your dad suggested. Bill |
| thnx man |
| Assuming it ran ok before the wide open run I say you sucked some dirt. Take the carb apart and clean all of the jets and passages. |
| If it is a 2000 and you have never changed the oil, I hope the previous owner did it. If you are the orignal owner then I wouldnt spend any big bucks. No more than it takes to get to somewhere like a local Chili's restaurant and see if they dumped the friers in the cans outback. You could just use some of that. |
| If you ran wide open for a long time Why wouldthe jetting suddenly change? How would you mysteriousy suck in dirt if your using an air filter? Do a compression test. You may have damaged the piston or cylinder. If piston no big deal just put in a new top end. If cylinder time for re-plate. In either case check the compression. Is it really hard to start now? Like have to push start it? |
| no its really easy to start it starts just like it use to and runs fine it just spits and sputters in half to 3/4 throttle then once im wide open its all god again. |
| Hmmmmmmm it has been doing it for a whole month. Do you think it will go away soon? If not, and in the meantime maybe you could disassemble the carburetor and slide the jet needle/emulsifier tube out and see if there is any junk behind it. Just a thought. |
| ossaggp1 has a good suggestion. I would start there. What does your plug look like? This will give you an indication if it is a jetting issue. You might want to start with a new or cleaned plug so you can get a decent read on it. Ride for an hour or so and check the color. |
| for the oil my '03 yz takes 650 cc of 10w30 |
Similar Threads for: 2000 yz 125 tranny oil change | ||||
| 2000 CR250 Oil Change | asmart82 | 2-Stroke Dirt Bike - Honda | 8 | 06-30-2010 01:24 PM |
| 2000 CR250 Tranny Oil Color | kinome79 | 2-Stroke Dirt Bike - Honda | 5 | 06-13-2008 11:53 AM |
| tranny | Randy11023 | General Discussion | 7 | 04-06-2005 06:51 PM |
| 2000 Yamaha blaster $2000 NJ | cmyyard19 | Dirt Bike & ATV's | 10 | 10-16-2004 01:12 PM |
| 03 CRF450 change tranny oil and oil everytime? | CaRdinalFan450 | 4-Stroke Dirt Bike - Honda | 1 | 01-16-2004 07:59 PM |
