1995 YZ250 Clutch problem
This is a discussion on 1995 YZ250 Clutch problem within the 2-Stroke Motorcycles - Yamaha forum, part of the 2-Stroke Motorcycle Forums category; Hi all, I have a 1995 YZ250, and I keep experiencing an issue with my clutch. After a bit of ...
Old 09-19-2004, 08:25 PM
Last Online: 04-13-2008 10:55 AM
Default 1995 YZ250 Clutch problem
Hi all,
I have a 1995 YZ250, and I keep experiencing an issue with my clutch. After a bit of time (maybe 45 minutes in this case), the clutch lever pulls to the bar, without any real actuation of the clutch. Closer inspection shows that the lever which enters the case to actuate the pushrod is much farther forward than it should be. I pull the clutch pressure plate off, pull the pushrod out, and re-seat the actuating lever, and everything is fine again. Put it all back together, ride for a while, and the same thing happens again. Closer inspection of the actuating lever shows some minor nicks in the dimple section that the pushrod rides in, but it doesn't appear to be enough to cause the rod to ride out of the dimple.
Any thoughts?
Old 09-20-2004, 08:40 AM
Aussie@Down Under!
Last Online: 01-22-2006 09:02 PM
Default Re: 1995 YZ250 Clutch problem
The lever (Push lever axle) most likely will be the cause of the problem.
I think your already on to this!
good luck!
Old 09-20-2004, 08:55 AM
Thanks for the response, guess I'll cough up the $45 for a new one to take one less variable out of the equation. I'll pick up a new pushrod while I'm at it for that extra peace of mind.
Thanks
Jim
Old 09-20-2004, 09:28 AM
MotoMan's Avatar
Floppy
Last Online: Today 08:39 AM
Yep I would say that the lever is probably the culprate (SP?). I would also carefully inspect the ends of the pushrod itself for wear, if it is dimpled as well, replace it while you are in there.
Good luck!!
Old 09-20-2004, 09:31 AM
The lever end of the pushrod is indeed dimpled, I assumed that it came this way from the factory since I don't have a new one handy to compare it to. Thanks for both of your input, and hopefully this fixes it!
Old 09-20-2004, 09:34 AM
MotoMan's Avatar
Floppy
Good luck man, and let us know how it turns out!
Similar Threads for: 1995 YZ250 Clutch problem
FS: 1995 YZ250 Forks with Racetech springs cetanepusher MC & ATV Parts & Accessories 4 05-04-2009 09:31 AM
found the problem with 86 yz250 bansheeduster 2-Stroke Motorcycles - Yamaha 7 10-03-2007 12:01 AM
a bit of a problem with my 86 yz250 bansheeduster 2-Stroke Motorcycles - Yamaha 15 09-29-2007 09:54 PM
1995 kx125 jetting problem joej85a 2-Stroke Motorcycles - Kawasaki 16 07-20-2007 03:08 PM
93 yz250 running problem yz250r 2-Stroke Motorcycles - Yamaha 4 11-30-2006 04:50 PM
