Old 04-25-2010, 04:46 PM
Last Online: 09-18-2014 03:10 PM
Default 1994 YZ125, Do I need a bottom end rebuild?
I just purchased a 94 YZ125 from a local shop. I was told that it ran but leaked antifreeze from the cylinder gasket. I pulled the cylinder and found that it has an after market Hot Rod and I need to know what to check. The rod has a little play when I push side to side but not any up and down.
Also I cannot tell much about the piston, it does have STD stamped in the top so I assume it is a standard bore OEM piston.
Are my rod bearings shot?
Thanks in advance.
Old 04-25-2010, 08:24 PM
Last Online: 05-10-2010 06:54 PM
There is always some side to side play in crank bearings. slip a feeler guage in between the rod and shim and then check against the minimum tollerance per owners manual. If it exceeds the tollerance you have to get the casings pressed apart and the crank professionally rebuilt by an automotive machine shop. BuT... I have never seen the crank wear out in all my experience.
Old 04-26-2010, 12:46 PM
I am used to rods that used solid bearings and have no play at all. I hope it is usable because if it needs rebuilt I can't afford to fix it.
Old 05-02-2010, 07:00 PM
peaceflood's Avatar
Last Online: 08-16-2016 01:23 PM
if it has less than 1/4 inch of travel i wouldnt worry about it.
take your stator cover off and try and move the flywheel up and down.
if there is movement, split the cases and open your wallet.
Similar Threads for: 1994 YZ125, Do I need a bottom end rebuild?
WR250F Bottom end rebuild help? evoman 4-Stroke Dirt Bikes - Yamaha 0 02-26-2010 01:58 PM
Bottom rebuild. KX250 jimzumba 2-Stroke Dirt Bikes - Kawasaki 1 03-25-2009 10:30 AM
Bottom end Rebuild Help Needed rollingtach 2-Stroke Dirt Bikes - Honda 10 10-20-2008 08:01 PM
Pipe with most bottom end for 05 yz125 mad_biker 2-Stroke Dirt Bike Forums 15 05-06-2005 01:04 PM
bottom end rebuild hanscvonbeaver 2-Stroke Dirt Bike Forums 5 06-06-2004 08:58 PM
