Old 09-25-2014, 03:01 PM
coolcaudill's Avatar
Last Online: 10-13-2014 02:56 PM
Default 1993 YZ125 HELP!! no spark issues
I was wondering if anyone had any tips for an issue with no spark. I have a 93 yz 125 I bought for cheap and have been trying to fix it up for a friend.
I have replaced the primary, secondary, and pickup coils and still nothing, please help!
Old 09-25-2014, 03:14 PM
arnego2's Avatar
a manual will help click here
Old 09-29-2014, 10:08 AM
VAL's Avatar
VAL VAL is offline
Last Online: 09-29-2021 01:03 PM
Where all the coils Known working units?
Have you disconnected the kill button?
I would look for a ground or broken wire.
Old 09-29-2014, 04:21 PM
I tested all of the coils and they all read the right ohms. and have unhooked he kill switch. think it might be a bad cdi unit as well. not sure if their is a way to test them
still haven't found a good online manual so I will have to kick down for the Clymer from amazon
just noticed a crack in my rotor that is causing it to sit uneven on the crank and rub on the side of the lower coil so now I suspect I will need to buy one of those before I further the investigation of the problem
thanks for the advice! ill update once I get some parts
Old 10-01-2014, 07:45 PM
Last Online: 03-22-2017 04:02 PM
Iv'e got Clymer for these bikes. PM me and I can try and help. Ive been doing a rebuild of a 1992 wr250z and it had a weird no spark issue that I resolved.
Better to find the problem bit, before you throw money at parts man
Will
Old 10-01-2014, 08:09 PM
"just noticed a crack in my rotor that is causing it to sit uneven on the crank and rub on the side of the lower coil so now I suspect I will need to buy one of those before I further the investigation of the problem"
This needs to be fixed as it could be the total source of the problem.
Similar Threads for: 1993 YZ125 HELP!! no spark issues
1993 RMX 250 Spark plug? SuzukiRace 2-Stroke Dirt Bikes - Suzuki 1 10-17-2012 08:40 PM
2000 cr80r spark issues 2strokejunkies 2-Stroke Dirt Bikes - Honda 6 09-09-2012 10:56 PM
CR250 spark issues mbosma 2-Stroke Dirt Bikes - Honda 5 08-26-2009 04:21 PM
CRF 450 2005 Spark Plug issues badboyz10 4-Stroke Dirt Bikes - Honda 5 06-10-2009 03:05 AM
Moto 4 spark issues JasonR 2-Stroke Dirt Bikes - Yamaha 0 11-03-2008 09:00 PM
