1989 yz250 parts?
This is a discussion on 1989 yz250 parts? within the 2-Stroke Motorcycles - Yamaha forum, part of the 2-Stroke Motorcycle Forums category; In case this is the wrong section to put this article, I'm new to this site and am a little ...
Old 02-13-2005, 01:19 PM
Twatson171's Avatar
Last Online: 07-27-2009 05:01 PM
1989 yz250 parts?
In case this is the wrong section to put this article, I'm new to this site and am a little unfamiliar with it. Moving on, I'm currently rebuilding a 1989 yz250 and am having a difficult time finding any sort of replacement parts (used or new). Ebay's the only place I've checked so far. Any ideas on where else I can go to find any parts for it? I appreciate any suggestions.
Old 03-23-2005, 11:24 PM
Speedfreek's Avatar
Last Online: 11-12-2006 09:39 PM
Default Re: 1989 yz250 parts?
What parts do you need?
Old 03-23-2005, 11:28 PM
1989kx125's Avatar
Last Online: 03-04-2006 12:35 PM
plastics, engine parts or what?
Old 03-24-2005, 12:06 PM
Twatson171's Avatar
grabit Re: 1989 yz250 parts?
Thanks for replying to my inquiry. I found plastics, as well as other odds and ends, but am in a bind with a few parts. The bearings/nuts/bolts on the swingarm are shot, and the dealership wants an arm and a leg for em. Also, I've been looking at replacement parts for th engine. Pistons and a "power valve" are tough to find. In case you have any luck, get back to me. I appreciate any help.
Also, I'll post pics in the next few days. It's currently stripped down to the frame, sandblasted, and rhino-lined. Plastics are purchased, along with reeds and a few other various items.
Old 03-24-2005, 03:02 PM
1989kx125's Avatar
basically the same story with my 89 except i just finished today. all it needs is colant. i'll post pics after i get the camera to work
Old 03-24-2005, 10:35 PM
Speedfreek's Avatar
Try pivotworks for the swingarm bearings.I'll look around and see if I have any of those bolts kickin' around here( I have two 89 yz250 bikes ). Are you missing the powervalve or are you replacing it because of worn tabs? The powervalve is still available from Yamaha,I wouldn't bother with used ones since they do wear quickly.If you are replacing it due to worn tabs I have a fix for that if you are interested let me know.The linkage usually gets pretty sloppy as well,I will be fixing one of those linkages tonight actually to send to a friend in the US.
As far as the piston goes pro-x and wiseco make pistons for these bikes which aren't a lot of money.
I've become pretty familiar with these bikes so if you need any help feel free to ask
Old 03-24-2005, 11:04 PM
quadfather03's Avatar
Last Online: 07-26-2009 01:06 AM
Speedfreek has the right names but if you want everything form one place you can go to [Only registered and activated users can see links. ] they have all the parts you could want for bikes and quads trust me. if you cant find an exact part just pm me an ill find it i have a list of over 40 mx and atv parts suppliers and im expanding my list every day. Good luck.
Old 03-26-2005, 12:59 PM
Twatson171's Avatar
Thanks a bunch for the replies. I'll check out those websites to get the last of the parts. As for the powervalve, I'll probably get a new one. The engines never been serviced before, so I think it would be a good idea to replace any parts that may need it. Anyways, thanks again.
Old 03-26-2005, 01:24 PM
Speedfreek's Avatar
Here's a link to a site that will give you an idea of what your yamaha dealer will charge you for parts.I've never ordered anything from that site,but it does give you prices which is handy.They use their own part numbers on that site so the part numbers from there won't do you any good,but I'll give you a link to Yamaha's site where you can get actual part numbers but no prices [Only registered and activated users can see links. ]
Old 03-26-2005, 01:35 PM
Speedfreek's Avatar
You will find that the powervalve linkage has been discontinued.If you e-mail me I can give you instructions on how to fix it.It's not to difficult if you are mechanically inclined. I do have a brand new powervalve linkage here but I'd prefer to keep it for my bikes .I also have a good used one.I really don't want to sell either but if you can't find one let me know and I will attemp to help
Old 03-26-2005, 01:46 PM
Twatson171's Avatar
You're the man speedfreak. I did notice the powervalve is discontinued, which sucks. I'll get a better look to see if its decent, but I may need some advice towards fixing it. That is unless you wouldnt mind parting with one of yours...
Old 03-26-2005, 01:56 PM
Speedfreek's Avatar
See if you can find one,only the 89 will fit,1990 they got 5mm shorter. you could buy a 1990-1996 linkage ,cut it,add a piece to the shaft and weld it to make it the correct length,but it's just as easy to fix your old linkage.To fix your linkage you will need a propane torch,a vice, and acsess to either a mig or tig welder,and a grinder.If you can get a hold of these tools let me know and I'll give you the rest of the details.
I'm hoarding parts,lol,between one friend and myself I think we have 90% of all the used 89 yz250 parts
Old 03-26-2005, 03:37 PM
Twatson171's Avatar
ok speedfreak, I'll see if I can find one out there. I'll get back to you if I find anything.
Old 05-02-2005, 09:02 PM
Twatson171's Avatar
So a quick update, in case anyone cares: Installed a new powervalve and complete gasket set. Newer back shock with brand new swingarm bearings. Too many upgrades to list here, but I'll post some pics tonight to give you an idea what it's looking like.
Similar Threads for: 1989 yz250 parts?
Parting out 1991 YZ250 1989 1990 1991 1992 sportfry65 MC & ATV Parts & Accessories 4 08-27-2009 08:56 PM
1989 yz250 suspension questions bitshifter 2-Stroke Motorcycles - Yamaha 0 12-02-2007 12:29 PM
1989 YZ250 Float Adjustment MotoRyder 2-Stroke Motorcycles - Yamaha 2 10-25-2007 12:38 PM
1989 YZ250 Issues MotoRyder 2-Stroke Motorcycles - Yamaha 0 09-28-2007 08:42 PM
stator parts for 1989 cr125 jandb917 Wanted Items 0 07-26-2004 03:50 AM
