1982 yz100j
This is a discussion on 1982 yz100j within the 2-Stroke Motorcycles - Yamaha forum, part of the 2-Stroke Motorcycle Forums category; Dose anyone know how to hook up a carb on an yz100j I have 2 lines that I have no ...
Old 10-13-2009, 08:53 AM
Last Online: 10-14-2009 07:52 AM
Default 1982 yz100j
Dose anyone know how to hook up a carb on an yz100j I have 2 lines that I have no clue where they go. One is coming out the bottom and one on the left side from the back of the carb I need help finding out where they go any help would b appreciated
Old 10-13-2009, 09:30 AM
DRGSin393's Avatar
Super Moderator
Last Online: 03-17-2010 07:55 AM
lines?? tubes, cables??
Old 10-13-2009, 11:10 AM
MXtras's Avatar
Manufacturer
Last Online: Yesterday 01:59 PM
I bet they are vent line connections.
Scott
Old 10-13-2009, 12:37 PM
kwmotocrosspunk's Avatar
Im SOUNDERS Till I Die!
Last Online: 03-12-2010 12:16 AM
one is your overflow/vent tube and the other is for draining the carb bowl with the carb on the bike
Old 10-13-2009, 01:30 PM
but do they have to connect to anywhere or do i just leave them on hooked b/c last time i left them unhooked they both just started to spew the fuel when i turned on the fuel and yes they are tubes sorry for my choice of words earlier
Old 10-13-2009, 03:51 PM
if they both started to drain fuel than you have 2 things to do
1. for the drain tube: on the bottom of your float bowl, there should be a little screw(either flat head or phillips) tighten that up(not heavily though! its soft aluminum!) and that should stop that
2. for the over flow tube, it is draining out of there because your float is set too high or you "needle and seat" are worn out
heres a good thread on float height
How to Set Float Height
if your float is set right or you get it and it is still overflowing, replace you needle and seat which should be more than a few bucks and it will solve all the problems, but its most likely your float height
---------- Post added at 02:51 PM ---------- Previous post was at 02:49 PM ----------
and no they don't have to go anywhere real special, as long as your over flow tube isn't obstructed by dirt and can vent to the atmosphere it should be ok to let it hang under the carb
Old 10-13-2009, 03:59 PM
ok thx i will give that a try when i get the chance
Similar Threads for: 1982 yz100j
I got a 1982 yz125 and i need HELP!!! Jordan #241 2-Stroke Motorcycles - Yamaha 5 02-08-2009 04:56 AM
1982 Yz 125 Help!!!! Jordan #241 Vintage Riding 2 01-29-2009 09:16 AM
dt100 1982 racersnake Motorcycles & ATV's 0 01-22-2009 07:31 PM
rm 250 1982 will not idle victor 2-Stroke Motorcycles - Suzuki 32 04-11-2006 02:06 PM
1982-85 kdx175 1989kx125 2-Stroke Motorcycles - Kawasaki 0 10-21-2004 03:45 PM
