Old 08-26-2010, 06:15 PM
Last Online: 08-29-2010 01:09 PM
Exclamation 1982 yamaha YZ490 help????
I have a 1982 yamaha yz490, and i am having a very hard time kickstarting it, is there anything i can do or maybe a mod or anything just to make it easier, plzz??
thanks,
Old 08-28-2010, 05:59 PM
merlyn1965's Avatar
Last Online: 11-30-2017 01:50 PM
Well, I do not like to be the bearer or sad news but you have to know.
The 490's are extremely finicky to get them to roar to life. I've tried voodoo, chicken sacrifice all to no avail. I did the head mod to lower the compression a bit and it did made it a little easier but not by much.
You have to kick it with a stong leg or push start it. I now stop on a top of a hill when I stop for a break just in case that kickstarting it would not do it.
For mine, I put on the choke when cold and I don't give any gas and when warm, I never twist the throttle or it will never start. So basically, do not try to start it like you would a 125/250.
As for being worry to stall it? It never cross my mind of ever stalling it anywhere, if it seems that it could happen, I twist the throttle a little and that is the end of any worries about stalling.
Good luck
Old 08-28-2010, 09:11 PM
The 490's I have been around were pretty similar to the large 2 strokes I have owned. They liked to be really rich when cold. To the end that some of their owners started doing like I did for cold starts: I turn the pilot screw in until it is only about 1/8 of a turn out. If your bike is in reasonable tune otherwise, that has it running in 1-2 kicks well below freezing. Bad lower end seals cause low speed lean conditions that can make a hesitant starter even worse. I chose to use the air screw rather than have a bike that loaded up at low rpms and downhills.
Hot, all the big two strokes I have ridden and or owned liked the throttle held wide open. That is just what has worked for me on bikes from both sides of the pond. Bings were designed for starting big two strokes (flood button), and nothing else.
---------- Post added at 02:11 AM ---------- Previous post was at 02:10 AM ----------
Cool dog Merlyn
Old 01-09-2011, 07:01 PM
Last Online: 02-02-2011 07:12 PM
ive got a 89yz490 and its easiest to start if u dont hit the throttle at all and kick it on the compression stroke
Similar Threads for: 1982 yamaha YZ490 help????
87 YZ490 chrisman 2-Stroke Dirt Bikes - Yamaha 6 01-31-2010 09:33 AM
Finding YZ490 or Vintage Yamaha Parts AV8 2-Stroke Dirt Bikes - Yamaha 3 12-23-2009 07:24 AM
1982 yamaha xt125 wiring help joe12 4-Stroke Dirt Bikes - Yamaha 0 08-11-2009 07:40 AM
1982 yamaha maxim xj750 "locked in gear" Nick232 Vintage Riding 4 11-13-2007 03:38 PM
79 yz490 yz490oc714 2-Stroke Dirt Bikes - Yamaha 23 07-02-2007 03:29 PM
