03 yz250 motor problemsThis is a discussion on 03 yz250 motor problems within the 2-Stroke Motorcycles - Yamaha forum, part of the 2-Stroke Motorcycle Forums category; ok guys i just got this yz and before i can ride it i need a crank, right case, the ... |
| ok guys i just got this yz and before i can ride it i need a crank, right case, the main shaft that the clutch assembly goes on and a standard piston. these parts can come from a 99 to a 05 to my knowledge if wrong please let me know or if you have some email me at [Only registered and activated users can see links. ] i would be interested in buy a whole bottom end thanks the world the people it came from bew out the crank rod bearings and then towed it behind a truck to free it up that in turn destroyed the shaft by breaking off the teeth which then picked up in the gears and pushed apart breaking the case |
| Sounds like you have a mess to fix. Don't be scared to look at buying OEM parts. The price of the case half might be up there, but the internal parts are not really all that bad. A few years ago I repaired an exploded YZ125 tranny and replaced almost every single part in the tranny and shift mechanism for around $800. E-bay is a good spot to check for the case half but can be a crap shoot. They usually go for about $150 or so for a good case half on E-bay. I think the OEM price is around $425. Here is where I buy most of my OEM parts - [Only registered and activated users can see links. ] and they are in your neck of the woods (Penn). I have bought several bikes from these guys, too. Scott |
| Ktm sx 125 02 motor 05 chassie... problems starting | Rocky_mx | 2-Stroke Motorcycles - KTM | 0 | 01-27-2008 06:24 PM |
| KD80 Rotary motor problems | TUK101 | 2-Stroke Motorcycles - Kawasaki | 11 | 05-11-2007 02:36 PM |
| 05 KX250 motor, YZ250 motor, what is the difference | UnsafeHaven | 2-Stroke Motorcycles - Kawasaki | 2 | 09-19-2005 12:35 PM |
| yamaha blaster motor problems | littlekeb | ATV/UTV - Yamaha | 16 | 10-28-2004 03:39 PM |
| Motor Problems | dixienw123 | General Discussion | 2 | 04-30-2004 11:41 PM |
