03 yz125 idle way to highThis is a discussion on 03 yz125 idle way to high within the 2-Stroke Motorcycles - Yamaha forum, part of the 2-Stroke Motorcycle Forums category; First some background, i bought an 03 yz125 already torn apart ready to be rebuilt. after getting most parts needed ... |
| First some background, i bought an 03 yz125 already torn apart ready to be rebuilt. after getting most parts needed i finally got the bike rebuilt but it wouldnt start so i jump started it and the throttle seemed to be stuck wide open. ive tried adjusting my throttle cable and idle screw....any ideas what could be the problem? |
| pull the air box off the bike and start it, check to see if the throttle is WFO by itself, if it is, then check the cable or breaks or kinks or routing issues, if the throttle is all the way closed but still runs at WFO than you have an air leak for a possible fix lube your throttle cable |
| You should be able to hear the carb slide slamming shut if you release the throttle from w.o.t poistion. (bike not running) |
| 2000 CR250 HIGH IDLE | ctroger24 | 2-Stroke Motorcycles - Honda | 5 | 12-12-2008 02:16 AM |
| 2002 cr250 High Idle? | kitsrider | 2-Stroke Motorcycles - Honda | 2 | 10-20-2008 10:10 AM |
| 1995 RMX 250 High Idle | Nod7667 | 2-Stroke Motorcycles - General Discussion | 8 | 08-26-2008 07:33 PM |
| yz250 high idle problem | TRUCKER | 2-Stroke Motorcycles - Yamaha | 1 | 04-02-2007 01:19 AM |
| HIgh idle on 04 YZ125? | 04whyzee | 2-Stroke Motorcycles - Yamaha | 5 | 01-05-2006 04:46 PM |
