'02 Yz 125 Carb HelpThis is a discussion on '02 Yz 125 Carb Help within the 2-Stroke Motorcycles - Yamaha forum, part of the 2-Stroke Motorcycle Forums category; Hello-
I am not a moto genius by any means, so excuse my lack of knowledge. I am having an ... |
| Hello- I am not a moto genius by any means, so excuse my lack of knowledge. I am having an issue with my carb dripping gas from the overflow pipe (the smaller diameter tube of all of them on the bottom of the float bowl) It used to drip here and there, but now it drips constantly after then engine has been running for any period of time. The only way it'll eventually stop is for me to turn off the gas, duh. I ripped the carb apart and tried to clean it the best I could; that did not do it. The float seemed fine and so did all the other parts inside there. My throttle valve was a little knicked in a couple spots and had also lost some of the chrome finish on the bottom edge. Is that an issue? Thanks!! |
| It is a float sticking problem. I have seen this about a dozen times on the 01 & 02 YZ125's. |
-Pintlar- |
| I had that problem on my 03 after cleaning the carb. I let it sit for a couple days, tried it again, and there are no more drips and the bike couldn't run any better. |
| It could be that the float level is too high, causing it to overflow as well. Last edited by Kenny400; 04-19-2005 at 12:51 AM. |
| Yep, gotta agree with everyone else on this. The fuel leaking out from the tube is from a float level issue. I would recommend reading and following Faded's useful guide on hot to set your float. How To Set Your Motorcycle Carburetor Float Level |
| I will check my float level and see if I need to make adjustments. Thanks for all the replies and I'll post again after I try and make the fix again. |
| i had the same problem on a yz250- i replaced the float needle and the overflow went away |
| Flat Slide Carb vs. Piston Valve Carb | cr85racer24 | 2-Stroke Motorcycles - Honda | 1 | 09-20-2009 09:38 PM |
| carb top cap | nathan | 2-Stroke Motorcycles - General Discussion | 5 | 11-20-2007 11:32 PM |
| need carb help | quadrider32 | ATV/UTV - Yamaha | 4 | 02-26-2006 11:30 PM |
| carb help! | Squirrel | General Discussion | 1 | 08-11-2005 06:11 PM |
| Gas from Carb | roggen_400ex | ATV/UTV - General Discussion | 5 | 06-08-2004 11:31 PM |
