01 YZ125 Water Pump Seal Replace
This is a discussion on 01 YZ125 Water Pump Seal Replace within the 2-Stroke Motorcycles - Yamaha forum, part of the 2-Stroke Motorcycle Forums category; Coolant was dripping from weep-hole... Realize now that I have to remove the entire crankcase cover to remove the impeller ...
Old 07-01-2009, 05:34 PM
Last Online: 03-07-2010 09:22 PM
Usflag 01 YZ125 Water Pump Seal Replace
Realize now that I have to remove the entire crankcase cover to remove the impeller wheel and seals - problem is the gasket for the crankcase had to be ordered and will take more than one week!!!
New track nearby i want to get on, water pump gasket looks okay minus grayish rubber layer - any chance to throw back on same gasket, put in coolant, and ride til the crank case gasket gets here???
Old 07-02-2009, 08:10 AM
MXtras's Avatar
Manufacturer
Last Online: Yesterday 01:59 PM
It's your bike but I would not. What you are repairing might cost $60 if you replace all consumables. Replacing a cooked motor will be 15+X that. It's your choice.
I would wait to fix the bike properly, but hey - it's your's. Do what you want.
Scott
---------- Post added at 10:10 AM ---------- Previous post was at 10:07 AM ----------
If you are carefull, you can pop the "crankcase" cover without damaging the gasket and re-use it. You can also re-use the waterpump gasket if the cover is removed carefully. Even a small amount of sealer could be used where necessary on a torn gasket.
But I would not run with a known bad water pump seal.
Scott
Old 07-02-2009, 06:03 PM
Default Thanks Scott!
The water pump gasket is okay, I also have a new one with the grayish coat seal - the old one is clean but that gray seal has burnt away - can you think of something i can put on the gasket, assuming i can also get the crankcase cover gasket off without damage, that will help seal for the short time being or should i just get them as clean as possible?
4th of July camp/bbq/dirtbike ride all in jepoardy!!!
Thanks for your good advice.
Similar Threads for: 01 YZ125 Water Pump Seal Replace
98 CR250 Water Pump Seal chuber01 2-Stroke Motorcycles - Honda 6 10-29-2008 11:34 PM
1991 kdx200 water pump seal? tapper1823 2-Stroke Motorcycles - Kawasaki 2 03-30-2008 02:09 PM
changing the water pump seal billybowlegs 4-Stroke Motorcycles - Honda 5 08-16-2005 11:39 PM
KDX200 water pump seal help aced32 2-Stroke Motorcycles - Kawasaki 7 03-29-2005 07:18 PM
03 YZ450F Water Pump seal problem. silliven 4-Stroke Motorcycles - Yamaha 2 09-20-2003 09:27 AM
