00' YZ250 makin weird noiseThis is a discussion on 00' YZ250 makin weird noise within the 2-Stroke Motorcycles - Yamaha forum, part of the 2-Stroke Motorcycle Forums category; I was just curious if anyone could help me out with this or had any idea of what the problem ... |
| I was just curious if anyone could help me out with this or had any idea of what the problem is. I have a 2000 YZ250 and when i slow down and come to a stop the engine revs from high to low repeatedly for a while. Someone told me that it could be the crank seal. If anyone could verify this or just help me out with this I would appreciate it. Thanks, Sam |
| air leak somewhere? |
| Definite textbook lean condition. Could be an air leak, main seal or intake manifold or it could be a stuck float. |
| A little lean on the pilot circuit maybe. Try screwing the air screw in a little, unless it is already out less than 1/2 turn then you will need a larger pilot jet. check for air leaks around reed valve to case mating surfaces. Or in the boot between the carb and reed valve. |
| Makin my yz125 blackish | yz85zak | 2-Stroke Motorcycles - Yamaha | 1 | 03-19-2009 10:12 PM |
| Weird grinding noise??? | dixienw123 | 4-Stroke Motorcycles - General Discussion | 5 | 07-04-2004 12:06 PM |
| 99 yz250 engine noise ? | eddiespresso | 2-Stroke Motorcycles - Yamaha | 9 | 06-22-2004 04:21 AM |
| Weird Noise On My KX100 | DirTBikE KiD | 2-Stroke Motorcycles - Kawasaki | 9 | 03-29-2004 10:10 PM |
| Question about makin a video | ThumperTDC | Photo & Video | 16 | 03-16-2004 05:50 AM |
