Old 08-26-2007, 02:43 PM
Last Online: 08-28-2007 12:45 PM
Usflag '00 yz 250 crank problems
my little brother bought a yz 250 and three hours into his first ride on the used bike he said that a lot of smoke came out of the pipe and then the piston siezed (or at least it wouldn't kick over). I pulled the top end off and the piston and top end look great, however, there was metal chips that looked copper all through the crank. one of them was wedged in there causing the crank to sieze. Also the the plastic part on the inside of the crank looked melted and had big gashes where the rod connects. i imagine this was all due to a bearing going bad and hope that i can just put a new crank kit in it and be ok, but i'm not well versed in small gas engines, especially 2 stroke. i would apprieciate any expert insight or experience to this problem. (PS- if there are any tricks or tips to take into consideration i would love to here them, i have yet to take the bottom end off and split the case because i'm worried about springs and gears and whatever else they put in these things flying all over.) thank you.
Old 08-26-2007, 04:27 PM
Last Online: 10-22-2008 12:10 AM
Default Re: '00 yz 250 crank problems
the melted part probably just melted due to overheating the same thing happened to my 04 yz 125 and the problem was the yamalube was heating up to much and melted the plastic so i put a new crank kit in and switched to Amsoil and its been fine since
Old 08-27-2007, 12:04 AM
Tdub's Avatar
Last Online: 01-22-2016 10:26 PM
Old 08-27-2007, 02:36 AM
yeah, it is the amsoil that fixed it.
Old 08-27-2007, 06:58 AM
mbogosia's Avatar
Last Online: 01-21-2008 08:02 PM
I just had the exact same thing happen on my yz 125. I have a 99 and was told that sometimes these cranks just go. It was the original so it got 7-8yrs of riding on it. After that I switched from 40:1 to 32:1 on my premix and I think I will switch to a better lube on my next quart.
Old 09-02-2007, 01:24 AM
I replaced the crank
Similar Threads for: '00 yz 250 crank problems
YZ crank Bluerider250 2-Stroke Dirt Bikes - Yamaha 0 05-27-2008 05:02 AM
New crank bearings, crank turns hard? acw592 2-Stroke Dirt Bike Forums 13 05-20-2008 09:06 PM
Do i need a new crank? CheM 2-Stroke Dirt Bikes - Honda 11 02-05-2005 11:23 PM
2003 YZ450F crank-shaft problems Frakke General Discussion 1 01-03-2004 11:18 AM
crank 426FrEAk 4-Stroke Dirt Bikes - Yamaha 4 12-31-2003 07:24 PM
