Go Back   All Things Moto! Dirtbike Forums > Dirt Bike - ATV - Suspension Forums > ATV/UTV Forums
Old 08-26-2004, 02:18 AM
CLM CLM is offline
Last Online: 07-08-2005 03:22 AM
Question Twisted Tecate
Greetings and salutations all,
I've been messing with my T-4 for a bit lately and came across some tweaked pieces, what I am most worried about however is the Tecate's steering stem, it has a definate about 4-5 degree twist to the left. Anyone have any suggestions on straightening it? I would just buy another but... well.. this bike has not really got many parts available aftermarket or oem
Or maybe... anyone know if a stem from another model might fit?
the other parts that I have found tweaked so far is the subframe and the left spindle, the spindle I don't think I'm going to try straightening it because.. well.. I'm afraid it will weaken it being aluminum and all And the subframe... it is really slightly pretzled, I have gotten the arms straight but the center is still twisted.. *&%^%$# I think I just need another person and two bars about 6-8 feet long applying preasure in opposite directions on each side of the twist. ;D
Chris with the Twisted Tecate.
Old 08-26-2004, 02:23 AM
CLM CLM is offline
Default Re: Twisted Tecate
Oh yeah... Reason I'm trying to straighten everything is I need the parts straight before I can start disassembling to have items powder coated
Old 08-26-2004, 06:13 AM
4strkepwr660R's Avatar
Last Online: 12-18-2008 02:20 PM
Call up East Coast ATV and see if they have any stuff...They have a huge inventory of used parts and machines.
Old 08-26-2004, 09:55 AM
2fun's Avatar
Last Online: 07-17-2019 01:32 AM
Don't know about the other parts mentioned, but as far as the steering stem, you might be able to heat it up with a torch and bend it back straight.
I HATE bent parts!:
Old 08-26-2004, 11:39 AM
CLM CLM is offline
Cool, I will try the heat thing, All I know is I don't have enough umph to do that without the heat... I've already tried ;D
Chris
Old 08-27-2004, 08:05 AM
Last Online: 08-22-2005 08:12 AM
Are you able to adjust your tie rods to get the steering stem straight again?
Old 08-28-2004, 12:18 AM
Last Online: 06-13-2013 05:37 AM
no if you move tie rods, it moves your tow in or out. DONT DO THAT! lol you want the front tires the same distance apart from left to right. measure the back, then measure the front. adjust accordingly. just a litt FYI
Old 08-28-2004, 12:58 AM
CLM CLM is offline
I know about the tie rods.. and I know how to adjust front toe, it's that with the twisted stem if I were to adjust to have the bars straight I would get more steering one way then the other where as if I straighten the stem before adjusting the toe, I will have equil steering both directions
After all there's nothing worse then a bike that only turns right when life seems to always be throwing me left turns :
Chris
Old 08-28-2004, 11:53 PM
CLM CLM is offline
Well the twists are out of the spindle subframe and steering stem... the stem was actually easiest to straighten... hear it with a hot wrench and turn slightly past the stops
Time for more exploritory tecate surgery
Chris
Old 08-29-2004, 12:57 AM
2fun's Avatar
Glad to hear you got it straightened out!
Similar Threads for: Twisted Tecate
kfx400 in a tecate dustywb1 ATV/UTV - Kawasaki 2 12-14-2007 12:04 AM
Any tips on getting plastics (fenders) to go back to a normal shape? (not twisted) jhendrix General Discussion 13 12-07-2007 10:35 PM
Hi From The NZ Twisted Crew! TwistedFMX Member Introductions 9 06-29-2007 05:36 PM
Twisted handlebars KX250 rut-head 2-Stroke Dirt Bikes - Kawasaki 28 02-18-2004 11:49 AM
Anyone else out there have A Tecate 4? CLM ATV/UTV - Kawasaki 93 11-28-2003 10:50 PM
