Go Back   All Things Moto! Dirtbike Forums > Dirt Bike - ATV - Suspension Forums > ATV/UTV Forums
Old 06-12-2019, 02:39 PM
Last Online: 06-14-2019 05:47 AM
Usflag 04 YFZ 450 no compression
Back story:
So I started leaking some oil and decided to get a gasket kit. I have an Athena 98mm stroker kit fyi. Almost everything went back together nicely at first. When I initially started it the compression was too high to turn it over enough to start it. I assumed this was a timing issue not allowing that exhaust cam to auto decompress while starting. Then things went wrong apparently. I did break a bolt on the cam cover that I had to have drilled out (had to remove head) and the decompression plug fell out and got lost but I replaced that. When I started it back up after getting it together there was no compression at all. It just turns over. I flipped the cams just in case they were 180 off but no change. I rotated the crank and the lobes are compressing valves as they should. I know it's timed right per spec (exhaust marks at 9 and 11 and intake 1 and 3). I even took out the spark plug and made sure piston was TDC and lined up with timing mark. Still no compression. When I turn it over and stick my hand over exhaust pipe there is an alternating suck/blow corresponding with a complete cycle. Does this sound like a stuck valve to any of you? Or something else? Before I pull the head back off I thought I'd seek some advise. Thanks in advance.
Similar Threads for: 04 YFZ 450 no compression
Low compression twistable_deer 2-Stroke Dirt Bikes - Suzuki 3 04-18-2015 07:12 PM
No Compression lesankim ATV/UTV - Honda 2 09-25-2010 06:19 AM
compression on a 125 rm 89rmdude 2-Stroke Dirt Bike Forums 2 12-26-2007 05:28 PM
what should my compression be on an 03 rm-125 shocker998md 2-Stroke Dirt Bikes - Suzuki 2 09-07-2007 01:13 AM
Compression 99kx250rules 2-Stroke Dirt Bike Forums 3 03-14-2005 03:41 PM
