Old 08-14-2007, 03:52 PM
Synyster06Gates's Avatar
Last Online: 02-27-2011 06:14 PM
Default Re: YZSKY.. (Husky CR125/Yamaha YZ125 crossbreed) won't rev past 3/4 throttle
wow looks good. sorry I cant help you with your problem though
Old 08-14-2007, 03:55 PM
Jethro's Avatar
Last Online: 07-25-2010 03:12 AM
Originally Posted by 91YAMAHA91 View Post
Thats a Rowdy bike man. good project. I have a 440 snowmobile engine I wanna stick into something maybe Ill find a golf cart or a go cart carcass laying around somewhere some day. Or a lawnmower thatd be kool.
There's a vaccum cleaner lying in my shed you could try it in...
Old 08-14-2007, 03:58 PM
91YAMAHA91's Avatar
Last Online: 09-02-2007 11:37 AM
That would be quite the shop cleaner wouldnt it hahah.
Old 08-14-2007, 04:13 PM
Jethro's Avatar
...guarantee the girlfriend wouldn't put it down, if nothing else the vibrations would beat the washing machine anyday!
Old 08-14-2007, 04:45 PM
It will be interesting to see what is actually wrong. Have you ridden a similar yz125? I am curious about any changes you made to the air box. Did you have to make any?
Old 08-14-2007, 04:51 PM
91YAMAHA91's Avatar
All I can say is LMAO
Old 08-14-2007, 05:07 PM
Jethro's Avatar
Well, it's the original Husky box and filter. Both carb venturi's are identical in diameter, and I'm kinda banking on the fact that even though they're completely different engines, they should both still displace roughly 125cc's with every stroke of the piston. I'm hoping that some fine jetting work will flatten out any minor issues raised by the transplant, I'm concerned though that generally jetting and reeds affect the lower rev range and not so much the top. I have no history with either of carbs, or the engine for that matter so I'm feeling around in the dark a little, I have no idea if either carb has standard jets or if they've already been changed (bearing in mind the YZ already had a set of Boyesens+cage fitted. Suppose this could even be a CDI issue or a crank case air leak, hope not though...
Old 08-14-2007, 05:18 PM
Go with what Higs suggested for a minute. remove the cover off of the power valves and see if they are moving freely. I was hoping that you airbox was the culprit as I have had similar experieces, but it seems to be something else.
Old 08-15-2007, 02:09 AM
Jethro's Avatar
... good suggestion, haven't checked the valves yet. I'm expecting the new reed cage etc either today or tomorrow so will wait until that's installed then check that the power valve's moving freely. Will update shortly.
Old 08-15-2007, 01:26 PM
HiG4s's Avatar
Last Online: 03-09-2013 07:29 AM
Which was faster, the YZ or the Husky? I've kept the original mounts for the Husky engine in place, so basically the engine's are interchangeable (if I can get the Husky running). Plan was to repair the Husky engine and re-install it, but if the YZ's a better engine I might not bother... probably good to have a spare though. Just wondering if I could stick on a third set of mounts for a four stroke... might be nice to have the option to change!
The Husky had more low end and better accelleration (until we had the YZ off to Eric Gorr and had it bored 133 and ported), both had screaming top ends. The YZ had better suspension. Both were great, I liked the Husky better, the YZ always seemed a little small to me ergonomically.
By the way, I like the black plastic on the Husky,, mine was all yellow and white, everyone thought it was a Suzuki.
Similar Threads for: YZSKY.. (Husky CR125/Yamaha YZ125 crossbreed) won't rev past 3/4 throttle
Yz125 wont pull after half throttle after new FMF Rev pipe... cougar207 2-Stroke Dirt Bikes - Yamaha 3 04-11-2007 11:53 PM
Throttle slide height adjustment 04 cr125 MGCR125r 2-Stroke Dirt Bikes - Honda 0 11-24-2006 03:56 PM
'02 CR125 Husky Fork Seals Leaking Roche5 2-Stroke Dirt Bike Forums 4 12-07-2005 12:23 AM
96 YZ144 & 99 Husky CR125 HiG4s Classified Ads 11 03-16-2005 02:57 PM
Yamaha 250F Full Throttle Start zebramask70 4-Stroke Dirt Bikes - Yamaha 5 10-03-2004 04:46 PM
