Old 01-05-2007, 04:32 PM
Moto man26's Avatar
Last Online: 07-07-2010 11:51 PM
Default Yz125 Rear Shock
Hi guys I would like to know what to do with my rear shock on my yz125.
When I sit on it, it takes a while to come back up.....I think that my rear shock is a gas shock because it has a little reservoir beside it. Do I have to bring it to my local bike shop and ask him to put more gas in it? Anyways please tell me what I could do to solve this problem.
Old 01-05-2007, 04:49 PM
Last Online: 01-12-2011 08:11 PM
Default Re: Yz125 Rear Shock
it sounds like rebound is the problem, i think you can adjust that on some shocks, im not sure how though, try looking in the manual
Old 01-05-2007, 06:49 PM
vintageguy's Avatar
Last Online: 11-22-2012 06:06 PM
Sounds like it dose need a re nitro and possibly a seal . buddys TT350 just went, maybe the same problem.
Old 01-06-2007, 02:26 PM
Last Online: 11-18-2009 04:31 PM
Yeah it's time for a rebuild how old is this shock and if you don't know when it was last done it's definetly time.
Old 01-06-2007, 09:23 PM
Last Online: 05-16-2010 06:30 PM
The first thing you need to do is make sure the rebound adjuster isn't cranked in too far (that's the one on the bottom of the shock near the linkage).
If that isn't the case, I would be willing to bet that you have never greased your linkage or swingarm pivot bearings, and now one or more of the bearings has seized. Pull the linkage apart and remove the swimgarm. Clean all of the bearings. Replace any that are worn. Grease them liberally, and re-assemble. I'll bet your sticking rear-end (the bike's that is, I hope yours isn't sticky )) will be fixed.
FYI-the nitrogen is not what makes the shock return to fully extended. That is the function of the spring. All the nitrogen does is keep the oil under constant pressure so it doesn't foam up as it's being repeatedly forced through the valving.
Old 01-08-2007, 03:42 PM
Last Online: 05-29-2012 01:15 PM
Ditto What chokey said.
Check your rebound setting first.
Grease your linkage no matter what.
While the shock is out, It's probably long over due to be serviced. Find a local suspension guru and have it rebuilt. Or send it out and have it done. Seal Head, piston bushing, oil, nitro and Labor should be about $100-120
Good luck
Ian
Similar Threads for: Yz125 Rear Shock
93 kx 250 rear shock jmac88 Dirt Bike Suspension Tuning 3 12-26-2008 10:41 PM
Rear shock.... 2001hondacr125 General Discussion 0 06-09-2008 08:36 PM
rear shock saltpacker 2-Stroke Dirt Bike Forums 1 04-14-2008 11:46 AM
WP Rear Shock bradd Dirt Bike Suspension Tuning 10 01-18-2008 06:32 PM
Rear Shock kawaboy22 General Discussion 0 07-16-2007 05:11 PM
