Old 02-09-2008, 03:34 PM
RoostRM125's Avatar
Last Online: 09-14-2010 09:12 PM
Default Won't Kick Start But Will Bump Start
Today at the track my bike started to foul a plug so I stopped riding and put a new plug in. From then on my bike would not start by kicking it with the choke on or off. But a couple of buddies help me push start it from the top of a hill and it took right off and ran great and hard until I would kill the engine. No matter if it was with in a second of killing the engine with the motor at full running temp. the bike would not start with the kickstarter but it would by bump starting it. What the heck could this be?
Old 02-09-2008, 03:59 PM
Synyster06Gates's Avatar
Last Online: 02-27-2011 06:14 PM
Default Re: Won't Kick Start But Will Bump Start
That seems exactly like what my bike does when it's flooded. Could it be that you're fouling plugs because you're way rich and just soaking the plug? I haven't fouled one plug since I got my bike. I'd check out the jetting
Old 02-09-2008, 04:05 PM
Blitz393's Avatar
without seeing the bike, i would guess it would be either a bad Top-end, a clogged pilot jet, or floats sticking or way out of whack. does the bike idle, or at least run the same at low RPM like it used to? do you have the correct plug? do you have a weak spark?
in the words of 50cent: "...i'll ask twenty-one questions...."
Rob
Old 02-09-2008, 10:23 PM
RoostRM125's Avatar
How much does reeds have to do with this issue, on one of my reeds a tiny piece of the corner is cracked off.
Old 02-09-2008, 10:49 PM
Crogg's Avatar
Last Online: 03-14-2019 08:10 PM
Just about everything! Replace the reeds and be done!
Old 02-10-2008, 08:37 AM
Blitz393's Avatar
actually yes, the reeds would definitely cause the problems you're having. they may be worn out in addition to being cracked. take the reed block out (since you're replacing the reeds anyway... right?) and look through the intake... you should not be able to see daylight through them. of course, if you have clear (composite) reeds you will see "light" but there should not be any visible gaps- the reeds should seal almost perfectly.
Rob
Old 02-10-2008, 04:57 PM
RoostRM125's Avatar
I'll replace them this week and see if it helps.
Old 02-10-2008, 11:08 PM
RoostRM125's Avatar
So is the problem the engine is getting too much gas and flooding?
Old 02-12-2008, 09:43 PM
RoostRM125's Avatar
Eddie, a jetting expert in Thumpertalk.com said he reason I have to bump start it is because it doesn't have enough compression. This seems right so I'm doubting the reeds will fix the problem. I've only put about 20 hours on the motor, isn't that quick for a top end to lose that much compression that it won't start?
Old 02-13-2008, 02:34 PM
VAL's Avatar
VAL VAL is offline
Last Online: 12-16-2018 03:22 PM
If the reeds are allowing some of you crank pressure to return through the carb you will not get the same amount of fuel in the combustion chamber as you would when they seat. THis could be the reason you need the addition RPMs you get when you are bump starting to make up for the "leak". Once started the volume of air going through the system at idle and about will mask the problem.
Similar Threads for: Won't Kick Start But Will Bump Start
Kick start merky 2-Stroke Dirt Bikes - Honda 5 12-24-2008 11:13 AM
How to bump start??? 99yz125 2-Stroke Dirt Bikes - Yamaha 17 01-22-2008 07:46 PM
Bump Start Henry General Discussion 21 10-25-2006 07:47 AM
bump start only when hot tincedar_2 2-Stroke Dirt Bikes - Honda 2 04-04-2006 05:51 PM
