Old 10-28-2007, 01:08 PM
ZFlower777's Avatar
Last Online: 04-29-2015 10:49 AM
Default weeping seals
So there are fairly new seals in my forks
(its a 2001 ktm 250exc, WP 43mm forks)
and ive noticed alot of fork oil coming from the seals.
is this normal for new seals to do?
and how could i fix this?
after a days riding, there is usually a drop of fluid coming off the bottom of my fork.
thanks, Zach
Old 10-28-2007, 02:49 PM
Default Re: weeping seals
Not normal at all. By the way, which post would like for your answers to come on?
If they had been on for very long I would suggest cleaning them, but improper installation is all that I can think of in your case, since they are new. That to me means doing it again.
Old 10-28-2007, 06:00 PM
Woody_YZF's Avatar
Last Online: 01-11-2015 01:36 PM
When I put my new seals in, the one leaked a little for the first ride. I think oil just got between the wiper and the seal. It has never leaked since then. If it's leaking there's definitely an issue.
Old 10-28-2007, 06:14 PM
dhighlan's Avatar
Last Online: 12-02-2008 10:00 AM
Try pulling up you wiper and using film negative or old tear off and clean the seal. If something gets in there it will leak. If this doesn't help you could have damaged the seal when replacing it. Did you cover the fork end with plastic wrap and grease when putting it on?
Similar Threads for: weeping seals
Oil leaking / Coolant weeping lbzrider 4-Stroke Dirt Bikes - Honda 12 03-18-2009 11:53 PM
Is it really that easy? YZ 125 seals ontherocks 2-Stroke Dirt Bikes - Yamaha 14 01-27-2009 08:40 PM
Weeping Seals ZFlower777 Dirt Bike Suspension Tuning 1 10-31-2007 05:35 PM
Fork seals. Geoff 2-Stroke Dirt Bikes - Kawasaki 7 01-16-2007 10:44 PM
OEM seals Randy11023 General Discussion 6 11-21-2005 08:47 AM
