Old 11-02-2007, 10:34 PM
Fireman87's Avatar
Last Online: 09-04-2010 09:02 PM
Default Stripped Bolt
Today when i was changing the oil in my case for the first time since i got the bike when i was putting the drain plug back in i realized that the previous owner had just about stripped the threads you can feel when your tightening it that the threads are real think and he has a rubber o-ring on there to keep it from leaking. Do you guys think it's best if i installed a heli-coil to fix it or do they make oversized plugs that are self-threading?
Old 11-02-2007, 10:53 PM
CRF731's Avatar
Last Online: 01-29-2018 10:48 PM
Default Re: Stripped Bolt
A heli coil has worked for me on a couple of bikes in the past.
Old 11-02-2007, 11:10 PM
Fireman87's Avatar
Alright thanks, thats what i was leaning towards i've used them in my truck before because the same thing happened someone stripped the drain plug on the oil pan, but my bike doesn't leak since that o-ring is on there but you can definatly tell the threads are messed up so i should fix it sometime.
Thanks for your input!
Old 11-02-2007, 11:15 PM
Freak's Avatar
Hook'Em
Last Online: 02-12-2019 07:55 PM
I'd do just that. Not many options, but I would rather do this then end up with a bigger bolt. Does not take much to strip the bolts on todays bikes.
Old 11-02-2007, 11:17 PM
Rotorranch's Avatar
Last Online: 04-05-2011 11:26 AM
Several ways to go. My favorite is the Helicoil. Great product! Fix almost any stripped threads. Takes a special tap and tool to install the insert.
Timeserts. They advertise on here ATM. Good product, needs a bigger hole than a Hellicoil. Uses standard SAE or Metric taps. I have had them come loose.
Keyserts. Similar to Timeserts, but with a key to hold them in place. I have some samples, but never used them.
All of these could be good in the right applications.
Rotor
Old 11-02-2007, 11:22 PM
Rotorranch's Avatar
Oh yeah, they also make oversize, self stripping plugs. You can get them in the "HELP" section of your local auto parts store. I guess they work in a pinch. I wouldn't wanna run Baja with one though.
Rotor
Similar Threads for: Stripped Bolt
TTR 125 Stripped Oil Drain Bolt mnhaq2000 4-Stroke Dirt Bikes - Yamaha 4 05-16-2010 05:19 PM
stripped bolt. need adviece Beans 2-Stroke Dirt Bikes - Honda 17 04-14-2009 09:25 AM
Stripped Oil Filter Cap Bolt Dirtbikindad393 4-Stroke Dirt Bikes - Yamaha 29 04-23-2007 08:51 PM
Stripped Bolt.. ethan General Discussion 10 03-03-2006 07:24 AM
stripped drain bolt love 2 ride General Discussion 8 03-12-2004 11:35 AM
