Old 04-20-2004, 11:12 AM
dwads77's Avatar
Last Online: 01-05-2015 02:52 PM
Default Oil for 2stroke break-in?
I usually run redline synthetic in the machine, however, I have read that it is not the best for the break in period. What would you all suggest for the first tank going through it? Thanks for the help...
Old 04-20-2004, 11:44 AM
04whyzee's Avatar
Last Online: 02-05-2009 12:42 PM
Default Re: Oil for 2stroke break-in?
10w-30 motor oil is fine for break in. Just make sure you check the back of the bottle and look for label that says "energy conserving" THis is the stuff you want to avoid putting in your bike. I am switching my YZ125 over to Shell Rotella 30w oil because I can buy it all day long for 11 bucks a gallon! It works great in my truck too so I have one oil for both of my machines! You can switch to synthetic after a full weekend of riding once the machine is fully broken in! http://mototuneusa.com/ <good info on top-end break in here>
Old 04-20-2004, 01:01 PM
crdemon's Avatar
Last Online: 04-12-2012 08:37 PM
Does it really matter what kind of oil u use for the breakin? I used the same honda synthetic stuff and it seems to work fine.
Old 04-20-2004, 09:37 PM
04whyzee's Avatar
From what I understand the synthetic oil may lubricate "too well" and cause the rings to not seat properly to the cylinder since this process relies on friction to smooth the cross-hatches in the cylinder.
Old 04-21-2004, 08:44 AM
dwads77's Avatar
Thanks for the responses...
Old 04-21-2004, 09:51 AM
I have not used Redline specifically. I have had no problems with any two stroke breaking in on synthetics. When I put one together for me or anyone else, I put it together with a dry ring and cylinder. You get full seating quickly. Years back when Kawasaki was the only one using a plated cylinder, the factory wrenches were doing that. Detroit did it on supercars in the 60's. It took some "unlearning" to do it, but it works well. Just remember to give the bearings their prelube.
If you are talking about a bike fresh off the showroom, don't worry, because they come with just a little bit of oil on the rings, and of course the prelubed bearings.
Similar Threads for: Oil for 2stroke break-in?
what 2stroke oil do u use and why? JDR215 2-Stroke Dirt Bike Forums 67 05-27-2008 08:44 PM
2stroke or 4? pauleh1 What Dirt Bike or ATV 19 01-10-2008 10:10 AM
new to the 2stroke world sbrjr89 2-Stroke Dirt Bikes - Yamaha 1 07-16-2006 05:59 PM
2stroke oil mix redryder250 General Discussion 11 09-26-2004 02:32 PM
4stroke or 2stroke? Mobius General Discussion 23 05-29-2004 03:55 PM
