![]() Guys , I just bought my 5 year old son a 49cc Pocket dirt bike ( not the best quality ) but its his first bike and I wanted something cheap for him to start out on , the only thing is I am having a heck of a time starting it . It is furnished with a pull start and I yanked on it about 100 times and it would not start. I have the correct fuel to oil ratio 50:1 , I checked the spark plug it was a bit fouled from the first ride but I since cleaned it and reinstalled it (still "no dice") . Cleaned the air filter , buggered around with the mixing screw (nothing) . I am totally new at this but willing to learn , I am determined to solve this problem on my own without having to bring it in to a shop , guys where should I start ? any advise would be greatly appreciated , thanks in advance . |
![]() Check the kill switch. Heard they can sometimes stick and ground out. Just a thought. You try bump starting it? ![]() |
![]() Quote:
![]() Oh yeah this site will come in handy too ![]() .....I'm the neighborhood expert on these junkers (not really by choice ![]() |
![]() Riptide's suggestion would also be a real good place to start ![]() |
![]() Thanks Guys , I will put a new spark plug in and throw fresh fuel in , Pragmatic393 yes I did get it started in the past , it was hard to start then , but when it warmed up it started in a couple of pulls with the throttle cracked a bit , Pragmatic393 what do you suggest for a ratio ? Riptide369 , how do I go about testing the kill switch ? |
![]() [QUOTE=Riptide369 , how do I go about testing the kill switch ?[/QUOTE] I would try to disconnect it from the wire harness, then try to start it. If it starts then the button is making contact in the switch. You try cussing at it? It normal doesn't help but sure makes you feel better ![]() |
![]() lol good suggestion use the f word a couple times then throw in a b word or two and should start right up lol ![]() |
![]() That's what I used to do with those little 2 stroke scooters, haha. |
![]() Quote:
![]() Oh yeah, check the chain tension and exhaust header bolts very often. Those bikes are freaking rattle traps. |
![]() Guys Checked the kill switch ,wasn't the problem , and cleaned the spark plug real good Not sure what I did but , i was fiddling around with the carb and I disconnected the fuel line between the tank and the top of the carb just to assure it was getting fuel and that the hose was not clogged ..... so when I removed it there was a steady supply of fuel , I connected the hose back up and for the heck of it I tried starting it ........ to my surprise it fired right up after a coupe of pulls ??????? What do you guy think ..... some sort of air lock within the carb? ![]() |
Thread Tools | |
Sons bike | Zman510 | Member Introductions | 2 | 12-03-2008 10:37 PM |
gah once again more trouble with this dang bike | 2001hondacr125 | 2-Stroke Dirt Bikes - Honda | 5 | 02-11-2008 04:56 PM |
pocket bike | ktmkid358 | Misc Riding Types | 6 | 12-09-2004 08:30 PM |
49CC Mini Harley VER. 2 POCKET BIKE BLACK | Rakk67 | Classified Ads | 3 | 02-25-2004 03:14 PM |
rm250 trouble starting | butlerox77 | 2-Stroke Dirt Bikes - Suzuki | 7 | 02-20-2004 11:58 PM |
