Old 11-07-2009, 05:11 PM
Last Online: 12-08-2010 04:39 PM
Default need help kx125
Hey I just got a 2001 kx 125 for a really low price($300). Now the bad news, water in the crankcase not coolant. Worse case scenerio is what? need a new jug,gaskit kit, and reseal the water pump shaft. Thanks I tried the search but most everyone had coolant which is usaully a simple fix.
Old 11-07-2009, 05:45 PM
AJ_YFZ's Avatar
Last Online: 01-30-2015 10:22 AM
Was it dropped over in water? Just had water in radiator?... Where is the water from?
Old 11-07-2009, 06:01 PM
no it wasn't dropped in water it had new gaskits in the top end. the radiator level doesn't change. I'm just wondering worst case how much money and what I'll need.
Thanks
Old 11-07-2009, 07:44 PM
AJ_YFZ's Avatar
The question is where is the water from?
Old 11-08-2009, 09:21 AM
dogger315's Avatar
Need some clarification. Is the water in the crankwell (which is
sealed off from the transmission) or in the actual crankcase mixed
with your transmission oil?
If it's the first case, remove the cylinder and use whatever means
to remove the water. Spray the crank with a water displacing
chemical (WD-40), reinstall the cylinder and go ride.
If it's the second case, try a transmission oil change, ride the bike
and see if the problem re-occurs. I'm guessing since there is no
coolant, the water is the result of condensation or pointing a
pressure washer in the wrong place.
dogger
Old 11-08-2009, 09:28 AM
Last Online: 05-04-2010 09:43 PM
did they make a kx125 4t? drain the oil out of the tranny. put new oil back in, go ride it for a few minutes and drain again, if it were me id be doing this a few times.... do you know where the water came from? is it condensation? is the case possibly cracked or a gasket not sealing correctly? theres really no way for us to sit here and tell you a worst case senario on this.. if your really worried your going to to have to tear the motor down and have a look and inspect things quite thurough.
Old 11-08-2009, 12:33 PM
dogger
Thanks for the info I'll get in the top end as soon as i get a chance, I'm finishing up my 86 yamaha tri-z at the moment. Just thought I might be able to order parts ahead of time but I guess i need to do some troubleshooting. Thanks for everyones response
Similar Threads for: need help kx125
00 kx125 Enjoi_yo 2-Stroke Dirt Bikes - Kawasaki 7 02-28-2008 03:09 AM
00 kx125 Enjoi_yo 4-Stroke Dirt Bikes - Kawasaki 0 02-26-2008 03:08 PM
01' kx125 blu4door Classified Ads 25 05-23-2005 06:53 AM
kx125 CRFDUDE17 2-Stroke Dirt Bikes - Kawasaki 5 04-03-2004 12:33 PM
Anyone know if a 1998 KX125 engine will fit into a 1995 KX125??????? KX125 Camerron 2-Stroke Dirt Bikes - Kawasaki 1 12-16-2003 04:32 PM
