Old 07-20-2012, 11:13 AM
Last Online: 12-30-2012 08:41 AM
Default Lean Bog?
Right, i've put a new and correct spark plug in my derbi senda 70 and it still isnt running right.
It makes a "Boooooooooooooooaaaaaaaaahhhhhhhhhh" sound in gears; 1, 2, 3 and 4
And it makes a lower pitched "Booooooooowwwwwww" sound in gears; 5 and 6 with no acceleration.
Is this a lean bog? Any ideas welcomed.
Cheers
Sheffy.
Old 07-20-2012, 11:30 AM
Last Online: Today 08:13 AM
Default Yes
Yes it could be, but more info needed.
How old is the top end on the engine?
Have you checked the compression?
Is the air filter clean?
Have you checked the fuel flow?
Old 07-20-2012, 12:33 PM
Cheers for the reply, its got : Brand new top end; Good compression; Good fuel flow and a brand new air filter.
I've ordered a new carb to engine inlet rubber as the other one is split. Could this be causing it?
Cheers.
Sheffy
Old 07-20-2012, 01:11 PM
Default Yes
Yes, but it could also give you some idle issues as well, but not always.
Old 07-21-2012, 10:07 AM
When warm the bike doesn't idle, I have to rev it up to keep it going. It also hesitates when you crack the throttle from cruising to accelerate. It ran a lot more responsive when I took the air filter off to check. Your opinion?
Cheers.
Sheffy
Old 07-21-2012, 11:19 AM
Default OK
Ok, what was your compression reading?
Did you instal the new carb boot?
Don't run it without the air filter!
Is the air filter overoiled?
It sounds like your may be running rich, but until the new boot is on and you check the compress it will be hard to tell.
Old 07-22-2012, 05:43 AM
I will get the compression reading tomorrow, when i go to the garage.
I just started it without the air filter.... Don't panic. But it seemed to me as if the idle was more consistant and the throttle response was sharper. So maybe when i put the new 'carb boot' in it will get the correct ammount of air/fuel.
Also the air filter after taking it the the garage, the head mechanic said it may be a little small.
Cheers for the help Paw Paw.
Sheffy.
Old 07-23-2012, 01:23 AM
if it runs badly warmed up it is usually a rich condition. if it improves with the air cleaner of, it is more convincing that it is rich. summer time requires leaner jetting to achieve similar performance characteristics to winter, though you likely will always get more power with the colder air of winter, particularly if it is dryer.
Similar Threads for: Lean Bog?
y is it lean?!?!?!?! oglejust 4-Stroke Dirt Bikes - Honda 4 09-24-2009 01:06 AM
rich or lean cowasaki1 2-Stroke Dirt Bikes - Yamaha 7 06-11-2007 11:05 PM
OOPS! IT WAS A BIT LEAN chris99 ATV/UTV - Yamaha 8 08-12-2005 10:41 PM
too rich, too lean, too old ? rooferrobbie 2-Stroke Dirt Bike Forums 23 05-25-2004 10:04 PM
Look A Little Lean??? 83SuzukiRM250 General Discussion 11 01-18-2004 07:45 PM
