Old 04-13-2011, 06:17 PM
KX Rida's Avatar
Last Online: 11-18-2014 07:21 AM
Default fuel ratio?
what ratio should i use for my 94' KX 250? Im using 40:1 does that sound about right? it was smoking too much 32:1.
Old 04-13-2011, 07:04 PM
Excessive's Avatar
Last Online: 04-15-2011 05:38 PM
air cooled = 32:1
water cooled = 40:1
so for you 40:1 is ideal
Old 04-13-2011, 07:37 PM
dodging_roost's Avatar
Last Online: 05-30-2018 07:46 PM
Interesting ..... all of the bikes I have had in the owners / service manual recommend 32:1, but then again I have ran as thick as 20:1 and as thin as 50:1 as per the oil recommendation.
Never saw a 40:1....
Thanks
Scott
Old 04-13-2011, 07:44 PM
supercr125's Avatar
Last Online: 03-02-2016 12:12 AM
@scott: i run 40:1, its in the middle of everything so its just about right, sometimes the mixture is wrong so it gives you some room for error since you can run it slightly leaner or richer because of mixing it not as specific if you could be and you dont end up running to lean or to rich.
keep running it 40:1 dude your doin good so far, get some pics up!
Old 04-13-2011, 07:46 PM
KX Rida's Avatar
32:1 was too much but 40:1 seems to be working
Old 04-13-2011, 08:34 PM
Last Online: 12-12-2014 02:36 PM
hmmm. i run 32:1 and while it does smoke it just makes my friends smell better since they are always behind me
Old 04-13-2011, 08:39 PM
bbrmotosports's Avatar
Rockin A class
32:1 and i don't smoke but i also dont bog my bike around
Old 04-13-2011, 09:33 PM
Mine doesn't smoke either 32:1 but I have also adjusted the jetting and I think I am pretty close.
Thanks
Scott
Similar Threads for: fuel ratio?
fuel/oil ratio for a yz85? cr250scott 2-Stroke Dirt Bike Forums 13 07-09-2012 03:08 PM
what oil/fuel ratio? UnknownWarrior 2-Stroke Dirt Bikes - Yamaha 10 06-28-2010 05:24 PM
Fuel/Oil Ratio? cr250scott 2-Stroke Dirt Bike Forums 5 05-26-2007 05:22 PM
fuel ratio??? TRXman86 ATV/UTV - Yamaha 10 04-01-2004 09:30 AM
87 TRX250 oil fuel mix ratio? acgeorge 2-Stroke Dirt Bikes - Honda 2 02-14-2004 08:54 PM
