Old 09-24-2018, 02:23 AM
Last Online: 07-12-2020 12:17 PM
Default free 2 stroke fuel/oil calculator + carb sizer
2 Stroke Fuel/Oil Ratio Calculator
Based on the engine oils viscosity at the higher upper cylinder temps my calculator can recommend the needed fuel/oil ratio. This method agrees basically with the best manufacturers but it can be specific to your engine as RPM and type cylinder cooling affect how much oil is needed. End the guessing game with my free calculator.
Carb Sizing Calculator
carb diameter = .8 x square root(cc x RPM/1000) was the formula I'm familiar with but once I thoroughly investigated the subject I found the manufacturers size the carb by the desired flow velocity, not by that formula. So I created my own formula to mimic what they have done.
Similar Threads for: free 2 stroke fuel/oil calculator + carb sizer
My carb leaks fuel out of the overflow hose at the bottom of my carb Danistheman 4-Stroke Dirt Bikes - Yamaha 21 07-05-2013 04:58 PM
Fuel Overflow from Carb Dirtbug 2-Stroke Dirt Bikes - Kawasaki 2 07-19-2012 03:15 PM
Fuel Injection For Ur 2 Stroke Is Here!! MxSkillz 2-Stroke Dirt Bikes - Honda 7 09-20-2011 08:58 AM
4-stroke Valve Shim Calculator (Excel) Woody_393 4-Stroke Dirt Bike Knowledge Base 11 02-06-2009 03:28 PM
How to Tip - 4 stroke fuel screw secrets╩ HOW TO TIP - 4 STROKE FUEL SCREW SECRETS Satch0922 4-Stroke Dirt Bike Knowledge Base 4 02-14-2005 10:04 AM
