Old 05-11-2008, 08:13 PM
mark 1987 930's Avatar
Last Online: 06-19-2010 08:10 AM
Default Crank bearing removal
What do the rest of you use (for tools) to remove crank bearings that have remained on the crankshaft when you split the case (magneto side).
The manual states to use a special bearign sepertor, but it's not cheap. I don't plan on re-using the bearing.. so I don't care if I damage it, but I don't want to damage the crank.
it's on there pretty tight.
How do the rest of you do it?
Old 05-12-2008, 07:39 AM
MXtras's Avatar
Manufacturer Dude
Default Re: Crank bearing removal
You pretty much have to use a bearing separator.
You definately do not want to bang up the crank - handle with extreme care and use the correct tools.
Scott
Old 05-12-2008, 10:55 AM
dellaquila's Avatar
Last Online: 07-08-2015 12:53 AM
Here's a video from RMATV that shows how to do it using their Tusk brand of separator. It's fairly cheap from them I'm pretty sure.
YouTube - crank bearing removal on atv or motorcycle
Here's the link to the Tusk tool he was using, $59.99
Tusk Crank Bearing and Gear Puller Set | Rocky Mountain ATV/MC
Old 05-12-2008, 12:54 PM
ironically, I have one of those, but it doesn't seem to fit right behind the bearing (not enough room). Although when I watch this video, I notice that the tool doesn't need to get all the way behind it like i thought.
Thanks.. I think what I have for tools will do the trick.
Old 05-12-2008, 01:26 PM
MXtras's Avatar
Manufacturer Dude
The vid says it all.
The only addition I would suggest is to use a "center saver" where the puller contacts the crankshaft. Or just use a soft piece of material to keep the shaft center in pristine condition for future use.
Scott
Old 05-12-2008, 07:51 PM
dellaquila's Avatar
Awesome, I hope that works out for you then! I'd like to buy all of those specialty tools from them so I can rebuild my bottom end, but that's around $180 for 3 tools!
Old 05-12-2008, 07:56 PM
I actually just order the flywheel/clutch holder as well as the crank seperator tool. I had made my own to split the case, but getting the crank out of the other side is a challenge, this tool will get it on.
I wonder if I should have ordered the crank installer as well!! I'll just stick the case in the oven and the crank in the freezer like I've done previously.
I hope I get this thing running soon again.
Old 05-13-2008, 01:11 PM
Does anyone know if the TUSK crank installer will work with a Crank that does not have ANY thread on the primary gear side? (none inside or out).
Old 03-14-2009, 07:07 PM
Last Online: 01-08-2011 05:55 AM
Just a few hours ago I had your problem with no bearing splitter. I do have a pipe vise though. I heated the bearing gently under a propane torch and then clamped the bearing in the pipe vise and tapped the end of the crank with hammer and a small wood block and the crank gently pushed out. Viola worked great.
Similar Threads for: Crank bearing removal
Swingarm bearing removal dangerSteve 2-Stroke Dirt Bikes - Honda 9 02-25-2009 04:46 PM
RH crank bearing removal TS185 rickthefix 2-Stroke Dirt Bikes - Suzuki 1 02-07-2009 04:03 PM
Shock Linkage Bearing Removal coss 4-Stroke Dirt Bikes - Honda 7 01-01-2008 08:19 PM
axle bearing removal yfs200bl ATV/UTV - Yamaha 0 05-15-2007 03:26 PM
Axle bearing Removal quadfather03 ATV/UTV - Honda 9 01-02-2006 09:15 PM
