Old 05-14-2008, 09:28 PM
Last Online: 05-28-2012 01:59 PM
Default The cases will not split!!! Help
I need to replace the crank on my 05 yz125 and Im using a crankcase seperating tool. I've got all of the stuff on the right side of the case removed.(Primary Drive gear, Clutch, All the shift mechanisms). Ive tried connecting the case splitter to both side and it just won't come appart. I can see that the glue is broken all the way around because it starts to open up but at the front of the engine it stays closed. Please help, I need any tips!!!
Old 05-14-2008, 10:22 PM
dellaquila's Avatar
Last Online: 07-08-2015 12:53 AM
Default Re: The cases will not split!!! Help
There has to be a bolt still tight somewhere. Have you seen the videos RMATV has on Youtube walking you through a YZ250 bottom end rebuild? They're in a few posts on here now too. Watch those and see if you're missing something.
YouTube - Motorcycle bottom end rebuild part 1 (of 3) crank & bearings
YouTube - Motorcycle bottom end rebuild part 2 (of 3) crank & bearings
YouTube - Motorcycle bottom end rebuild part 3 (of 3) crank & bearings
Hope those help!
Old 05-14-2008, 10:33 PM
Hope those help!
The manual says there is only twelve bolts and I removed twelve bolts. I'll tell you though, its pretty frustrating when you buy a case splitter and the cases won't split.
Does anyone know if heating up where the cases meet helps them come apart.
Old 05-15-2008, 03:17 AM
JDR215's Avatar
Last Online: 12-18-2011 09:53 PM
im not too sure with the yamis, but on hondas there are a couple of bolts inside the stator cover on the left hand side of the engine, sounds like bolts are still somewhere to me.
Old 05-15-2008, 04:26 AM
psycho393's Avatar
The cases should just about fall apart if you have all the bolts out.
Old 05-15-2008, 01:21 PM
Fireman87's Avatar
Last Online: 09-04-2010 08:02 PM
You have to take the flywheel and stator plate off as well (atleast on my honda's you do) And like they said above when everythings out i don't even need a case splitting tool i can grab ahold of my jug bolt stuts and pull a little bit and the'll start to come apart where i can stick my fingers in between the cases
Other than that, good luck hopfully you can figure it out.. oh and I don't know if you have a manual or not but buy a Clymer manual, one of the best manuals imo for tear downs and putting it back togeather, has detailed descriptions, pictures and torque spec. charts.
Old 05-15-2008, 03:50 PM
I got the three bolts in the stator. I have the stator and the flywheel off. I also have a manual but I don't know why they won't come apart. Somebodys had to of had this problem before!!!
Old 05-15-2008, 04:11 PM
crfjedi393's Avatar
Last Online: 03-31-2015 09:33 PM
Yep. But it's ALWAYS been because I was overlooking one last bolt. Keep searching.
Old 05-15-2008, 07:36 PM
mark 1987 930's Avatar
Last Online: 06-19-2010 08:10 AM
Did yo try light taps with a rubber mallet while your put some tension with the case splitting tool?
Old 05-15-2008, 07:55 PM
I have tried a rubber mallet and I pretty positive that I got all the bolts, I took off twelve and thats all theres supposed to be but I'll check again.
Old 05-15-2008, 08:03 PM
crfjedi393's Avatar
Get a flashlight and check everywhere inside and out. I've only split CRF cases but there are some bolts in not-so-obvious places.
Old 05-16-2008, 02:34 AM
JDR215's Avatar
it is a yamaha............
hope u get it man, without smashing it to bits with a sledge hammer.
Old 05-16-2008, 07:33 AM
If you are 100% positive that you've removed the bolts holding the cases together, how hard are you turning the case splitter tool? IF they've never been apart, chances are it'll be tough the first go around. My KX made a huge poping sound when it first split.. I was worried at first that I stripped the threads.. but no, it had finally came undone. It's a tight pressed fit between the crank, bearing, and case. I had to continue to use the splitter to seperate the cases completly.
When you stated you saw it split, how much was it? a hair, 1/4inch?
Old 05-16-2008, 04:21 PM
It was only like a hair but it sucks right back down. The back will split like a 1/4 inch with my hands
Old 05-17-2008, 05:16 PM
Thanks for the help guys. I finally got it to split. There wasn't any bolts left but I made a nifty little engine stand for it so I could really crank on the splitter and it made a huge pop and then it came apart. I got The transmission out and everything. It seems that the crank wasn't the problem at all but one of the case bearings was really rough so I guess it won't be as expensive as I though it would be.
Old 05-17-2008, 05:18 PM
Oh and I'll try and get some pics up if any one wants to see anything. Tell me if it all looks good.
Old 05-19-2008, 06:37 PM
Congrats.. When mine poped.. i just about my pants.. I thought I had stripped some thread or something.. That's why I wrote it in my previous post. I had to turn the splitter pretty hard to get it open.
I'm jsut waiting for parts to put mine back together now (transmission input shaft split in two..).
Similar Threads for: The cases will not split!!! Help
unable to split cases 82 ke125 targis34 2-Stroke Dirt Bikes - Kawasaki 0 09-07-2008 03:33 PM
i have to split the cases...againnnn YZ125motoracer 2-Stroke Dirt Bikes - Yamaha 8 05-31-2007 03:00 PM
Time to Split the Cases crfjedi393 4-Stroke Dirt Bike Knowledge Base 52 05-31-2007 09:05 AM
Should I split the cases..... taylormade 2-Stroke Dirt Bike Forums 11 09-20-2004 06:17 PM
Split my friends cases tonight MATTXR250R General Discussion 24 04-24-2004 08:16 PM
