Old 07-26-2012, 01:43 PM
Last Online: 08-02-2012 09:21 AM
Default bike runs wide open during cold starts
Hey guys, im new on here, i have a problem with my 94 kx 250, it seems like after my bike sits for a while (1 week) and i start it, it runs wide open for about 10-20 seconds, so I took the carb apart to see what it looked like, very clean inside, no dirt or any kind of build up was there. After that initial crank the bike runs fine, no ideling problem or anything. This started after I went riding and accidently rode my bike off into some deep water, I took the plug and and there was some water on it, im not for sure how much water was in the head, but after about an hour of kicking it and pulling the plug out and drying it off it finally cranked again, im assuming this would cause a problem, but how, ive also read that an air leak would cause it to run wide open, but like i said, it only does it after it has been sitting for a week, then it runs like a champ, this is my first 2 stroke and any help would be appreciated, is there maintenace i should do to it when not riding like draining the fuel out of the carb during the week or something?
Old 07-26-2012, 02:15 PM
it does sound like an air leak. it depends on the fuel. i have no problem storing mine for weeks on pump gas i get here which is "cornfree". if you get ethanol additives i guess it is worse. so i would dump it each time and drain the carburetor and refill with a little bit of avgas probably. or just run better fuel to start with. there are some things i dont like about avgas, but nothing stores like it. that i have tried anyway.
Old 07-26-2012, 02:42 PM
Last Online: Today 08:22 PM
Default OOps
Hot engines and water don't mix. It sounds like you have an air leak.
Old 07-26-2012, 02:50 PM
Thats what I was afraid of. But it I had an air leak wouldnt it run wide open all the time, or would it just be during cold starts. What is a good way to verify an air leak?
Old 07-26-2012, 04:55 PM
Default OK
Ok, a leak down test would tell you for sure.
Old 07-26-2012, 06:22 PM
FRODAD393's Avatar
Last Online: 03-19-2017 10:03 AM
Scared the crap out of me when it happened to my bike! Broke the carb down and cleaned it. That solved the problem.
In case you don't find an air leak which I would not rule out.!
Old 07-27-2012, 04:26 PM
Randog Leader's Avatar
Does it do it at all when it has sat overnight?
Old 07-31-2012, 02:00 PM
no, it doesnt do it after just one night, and i have cleaned the carb but it really didnt need it, it was spotless, im just going to take it to the shop for the leak down test like was advised, i was just hoping i could get on here and maybe someone had a similiar problem that wasnt a air leak, thanks bros
Old 07-31-2012, 02:01 PM
Yep, sounds like your air leak is being introduced after the engine is warm.
Similar Threads for: bike runs wide open during cold starts
Wide open when starting. swescott 2-Stroke Dirt Bikes - Honda 17 05-03-2012 04:16 PM
01 cr 250 running wide open at start??? Dennyray 2-Stroke Dirt Bikes - Honda 4 04-05-2011 09:52 PM
89 YZ 250 WIDE OPEN ON KICK. dc6587 2-Stroke Dirt Bikes - Yamaha 5 06-30-2009 02:03 PM
01 kx250 starts but stuck wide open TeamGreen2323 2-Stroke Dirt Bikes - Kawasaki 6 07-03-2007 12:25 PM
Wide open Austin225 General Discussion 2 05-14-2004 04:33 PM
