Old 02-28-2006, 02:31 AM
Last Online: 06-26-2008 01:52 AM
Default BIKE PEAK REVVING
Ok my bike was running normal, tonight i decided to take off the carb, give it a clean and inspect the reed valve. Last time i put the carb back together i didnt tighten the float bowl screws up tight enough so i was leaking a little bit of fuel and the bike wasnt idling. I fixed it all up tonight, put it back together, took 20 kick's to get the thing going again and then when it started it was idling super high, i adjusted the air screw prety much all they way out and it didnt do a thing. I didnt have enough time to pull it apart and try put it back together again so i have a few question's before i try again tomorrow. Is it to do with my jetting, air screw. Or mabey the throttle valve is not inserted properly? Any help would be great.
Thanks
Old 02-28-2006, 04:04 AM
crazyrydermx's Avatar
Last Online: 08-28-2006 03:36 PM
Default Re: BIKE PEAK REVVING
You most likely have a leak...check over for leaks, especially where you disconnected the carb, and see if there is anything.
Make sure you have inspected the carb and reeds completely!
Old 02-28-2006, 09:09 AM
BODYCAST's Avatar
Last Online: 02-26-2009 11:32 AM
The same thing was happening to me, i found a pinch in the radiator hose and fixed it, but it started up again shortly after. Thing is i just had a set of reeds put into my bike by iornhorse.....if it does not stop im going to take it back to iornhorse and tell them to fix it. Do you think it will hurt your bike to ride it like this? My bike still ran great.
But back to the original poster....you might want to look at your throttle cable. OR the radiator.
Old 02-28-2006, 09:18 AM
I thought your was going bing bing bing bing?
Old 02-28-2006, 09:24 AM
BODYCAST's Avatar
It was when i would get off the throttle...................but lets not start that again.
Old 02-28-2006, 09:30 AM
So is that problem fixed completely? Now you're just having this current problem that you just described?
Old 02-28-2006, 01:32 PM
kx_rider53's Avatar
Last Online: 06-13-2014 08:12 AM
Its probably an air leak.
Old 02-28-2006, 02:22 PM
CspineRider's Avatar
Last Online: 04-01-2008 08:02 PM
Make sure your throttle cable isnt stuck somewhere. And if you jetted the pilot leaner and your air screw is all the way out, it will idle high. Is it just idling high or is like it's pinned. If thats the case, you might want to check your spark plug also to see of there was any damage done to it
Old 02-28-2006, 04:13 PM
It's liked it is pinned lol. It has not air leak's now, it had an air leak before and i was adjusting the air screw so i could ride it that day. Im gonna play around with it tonight and see what i can do. Thank's for the help guy's. And the way it is right now i dont think i could ride it unless i want to seize it lol. I think she's running super lean lol. More help would be great guys
Old 03-01-2006, 10:54 PM
crdemon's Avatar
Last Online: 04-12-2012 08:37 PM
Maybe im confused but to u know what an air leak is that their refering too? because an air leak could be a puncture in ur carb boot or somewhere where more air than should be is getting through. I dont think that adjusting the idle skrew fixes that. back in my cr days i had a similar problem and it had to do with the throttle cable.
Similar Threads for: BIKE PEAK REVVING
Peak Voltage Adapter? spartanbiker_117 2-Stroke Dirt Bikes - Honda 0 09-24-2008 02:38 PM
Revving Up YZ 250 RIDER 2-Stroke Dirt Bike Forums 6 09-17-2007 07:17 AM
sneak peak Freak 4-Stroke Dirt Bikes - Honda 12 12-05-2006 07:15 AM
Deseret Peak - Wed 8/24 AW Woody_393 Racing, Group Rides, Post Ride Reports 0 08-23-2005 10:16 PM
deseret peak dunerider4 Riding & Recreation Areas 1 03-10-2005 03:52 PM
