Old 02-04-2017, 10:34 PM
Last Online: 03-31-2017 08:54 PM
Default 99 cr125 ran fine now it won't start
Hey guys, this is my first post here, I've tried everything I can think of so any feed back is much appreciated.
Recently replaced both crank seals. After the bike started up easily and ran fine, i did not have a chance to ride it because iit' snowing. After everything was back together I realized I forgot to install the pin which holds the powervalve arm on, so iI removed the exhaust and iinstalled the pin, i also removed the left exhaust valve cover to inspect it, when I removed it a good bit of premix/ sploog ran out. I also replaced the waterpump gasket because it had a very slow drip. Replaced grips with locking grips that required changing the throttle tube, Changed the transmission oil and Put everything back together and now the bike will not even try to start, here's what iI've tried so far,
checked spark out of cylinder- looks nice and blue
Cleaned the carb twice, replaced both jets and needle ( had a jd kit for it)
Replaced fuel line
cleaned all electrical connections, grounds ect.
tried starting it with the silencer removed
Igave it a sshot of starting fluid in the spark plug hole and it fired one time but i iimmediately shut it off because it revved up real high
Tried putting a tiny bit of premix in the spark plug hole and nothing, doesn't even try to fire
inspected reeds , which are new anyway
Tested compression- 150 psi cold
disconnected kill switch
checked for broken wires
The mix gas Ihave is a couple months old but since it was just running fine, iIfigured that wouldn't be a problem
I'm out of ideas, tthe only thing i can think of is that the plug isn't getting spark when it's under compression? Maybe a bad coil or stator? How would Igo about testing the spark while its in the cylinder ?
Or maybe I somehow created a large airleak? Which I am not sure how that could have happened by only doing those few small repairs,
I'm very confused because the bike started so easy only a few days before i did those things to it, but nothing i did seems like it would cause this issue,
I have yet to try and bump start it since there'sa foot of snow in my yard, any help would be great guys. I have to much time and money into the bike to give up on it
Old 02-05-2017, 08:16 PM
Default fixed
After pulling my hair out for all night I think i have it figured out, all I did was remove the airbox and blocked the carb intake about 90% and it fired. I figured Imay have a big air leak since starving it for air was able to get it going. So i assembled everything started it up and it went like the throttle was wide-open, so I shut it off and began to check for leaks, didn't see anything so I put some slack in the throttle and turned out the idle screw a bit. Now it starts right up first kick. Kind of odd, i swear i kicked the thing a hundred times and it showed no signs of life untill i choked the carb
Similar Threads for: 99 cr125 ran fine now it won't start
95 yz 125 was ripping fine then bogged out and won't start help please! Diirt444 2-Stroke Dirt Bikes - Yamaha 8 06-24-2014 09:44 PM
95 yz 125 was ripping fine then bogged out and won't start help please! Diirt444 2-Stroke Dirt Bikes - Yamaha 5 06-24-2014 09:23 PM
bike will start and run fine but wont clean up 93wr500 2-Stroke Dirt Bikes - Yamaha 22 08-03-2011 06:16 AM
HELP bike running fine, landed from jump, died, and wont start now!!! HELP lilsuperman 2-Stroke Dirt Bike Forums 5 04-14-2006 11:42 AM
98 cr125, will not start when hot MooseRacing552 2-Stroke Dirt Bikes - Honda 14 09-03-2004 12:57 PM
