94 RM250 stator coil readings?
Hi,
does anyone know what the correct resistance readings for a stator coil, off an 94, RM250R should be, also the resistance readings on the secondary coil and is there a way of testing the CDI unit with a normal automotive multi meter, I've not had any experience in checking anything like this before so what wires am I checking against, for example I have 5 wires coming from the stator coil, which wires should I attach the multi meter probes to inorder to check the windings,same with the secondary coil and CDI. Any info would be much appreciated, I've also posted a question on the 2 stroke forum for Suzuki motorcyles, headed Suzuki Rm250 non starter. |
