Old 02-19-2010, 01:33 PM
84cr250's Avatar
pro desert
Last Online: 11-25-2013 07:12 AM
Default 81 mc 490 v. 83 mc 490
the 81 maico 490 was supposed to be the best, and i've been wanting to get one for along time, but i heard the 83 had a top end of around 112mph. so has anyone heard if it really goes that fast. it was supposed to be for desert racing and was geared 16/48. and if it does go that fast does anyone know if you can gear the 81 to be just as good?
Old 02-19-2010, 05:32 PM
OLDMXRACER 393's Avatar
Last Online: 05-01-2018 09:41 AM
Hopefully the resident "Maico Man" sees this and you'll get the straight scoop. I'm no authority on Maico, but I do know the Sand Spider was the desert model. Doubt if it came geared stock to do 100+ though. H, where are you?!
Old 02-19-2010, 06:51 PM
Big Maico 393's Avatar
Super Moderator
Last Online: Today 06:46 PM
The 81' 490 was known as the best Motocrosser & the "E" model was the enduro with a wide ratio transmission. I don't know what the top speed of the E model was.
The 83' Spider was the 4 speed Motocrosser & the Sand spider was the 5 speed big tank enduro/desert racer. I'm sure that you could gear one to hit over a 100mph, I just don't know much about them. I would have to do some checking with a few guy's to find out.
The motor in the 83' is a Brute & is really scary fast!
Old 02-20-2010, 11:53 AM
Ekholm's Avatar
Last Online: 06-03-2013 06:19 AM
My question would be, how do you stop the beast once you get it going that fast??!!
110mph + drum brakes =
Old 02-22-2010, 10:46 AM
84cr250's Avatar
pro desert
The 83 490 Sand Spider was built for one thing only and that one thing was flying across the desert at a high rate of speed while keeping the rider in the saddle and in control. We felt this bike would be good to test against because of it's 112-MPH top speed. The Sand Spider came with a 5 Speed Wide Ratio Transmission, 48 tooth Rear Sprocket and a 16 tooth Counter Shaft Sprocket. i got this from Opferman Motors
Old 02-23-2010, 10:51 AM
84cr250's Avatar
pro desert
The Fastest Stock Dirtbike Ever Built -
123.75 miles per hour on a 1981 KTM 495-type in fastest stock dirt bike on google.
Vintage: The Fastest Stock Dirtbike Ever Built - 123.75 miles per hour on a 1981 KTM 495 - Dirtbike at Off-Road.com
Old 02-26-2010, 10:53 AM
84cr250's Avatar
pro desert
does anybody have any ideas at all on this?
