Old 05-26-2010, 05:04 PM
Last Online: 09-01-2012 07:55 PM
Default 01 CR250R Pro-Smoke.it
Iím running castor 927 @ 32:1 w/93 octane in my 01 CR250 and it will smoke very bad and run rough when it first starts up or if I shut it off for a few minutes then get back on it. After I rev it out once it runs fine from then on. I thought it was leaking fuel past the float needle and seat so I replaced them and checked the float level. Still does it, has anyone else had this problem?
Old 05-27-2010, 01:16 AM
I have used other castor based oils without that problem. Crank seal? Jetting?
Old 05-28-2010, 04:07 PM
I have all stock jets and settings, good reeds, new cylinder piston and rings. The crank was tight when I picked it up so I haven't checked the seals yet. Strange thing is, it will only do this when I kill the engine for a few minutes. It I would run it all day without stoping the engine it will run great all day.
Old 05-28-2010, 11:31 PM
stock jetting is a little on the fat side for most conditions. just curious, do you turn the gas off when you put it up? ride in a hot climate?
Old 05-29-2010, 07:22 PM
Yes, I shut the gas off, I've even tried running it out and it will still smoke and run rough, until I rev it out once. Could it be possible for the black oily stuff that blows out the exhaust to be leaking off the exhaust valve into the cylinder? I guess I need to do a leak down test.
Old 05-30-2010, 01:41 AM
I would look for a bad crank seal, clutch side, but do them both.
Old 07-18-2010, 11:43 AM
I've changed both crank seals and its still running bad. I had put a new plug in and it ran worse, so I decided to check out my ignition system. I ohmed my coil and it is out of spec. Service manual says the resistance between the primary and secondary should be 4-8 ohms, my coil is reading 3k ohms. I ordered a new coil and hope this fixes my problems.
Old 07-20-2010, 06:50 PM
burtonbutt1's Avatar
Last Online: 03-12-2015 10:27 AM
I was just reading this the other day:
http://www.eric-gorr.com/model%20tuning%20tips.pdf
If you look under the Honda cr250, they are known to have the "secondary coil" malfunction.
So, at least it's normal and there might be some good info in there for ya.
-Marc
Old 07-30-2010, 11:04 PM
hondaboy66's Avatar
Last Online: 11-14-2011 09:21 PM
Thumbs up cr 250
hey im going to get a 2002 cr. 250 the dude says it has a brand new motor do u know anything that i could check to make sure http://www.allthingsmoto.com/forums/...ons/icon14.gif
Old 07-31-2010, 11:58 AM
Once you do that, don't be at all surprised if you don't find the stock jetting a whole lot rich. Particularly for summer riding.
Old 07-31-2010, 01:24 PM
Brand new motor like out of a crate?? Probably not. Receipts are the only way to tell (kind of) with out tearing it down. Might be able to take the pipe off and peek inside at the piston to see it's condition.
Old 07-31-2010, 04:23 PM
David_L6's Avatar
Last Online: 10-05-2015 02:33 PM
I bought a brand new motor for my 2002 CR250 last summer, so it is possible.
http://img842.imageshack.us/img842/3...r250rmotor.jpg
Uploaded with ImageShack.us
Similar Threads for: 01 CR250R Pro-Smoke.it
i wanna see your 2-smoke...........ANY 2-smoke DUDEONAYZ125 2-Stroke Dirt Bike Forums 217 03-30-2011 01:08 PM
No smoke Vetteman Mini Dirt Bike Riders 5 02-18-2010 07:12 AM
KTM Smoke. crfjedi393 Photo & Video 0 11-05-2007 08:43 PM
smoke, red_rever230 General Discussion 3 09-22-2004 02:44 PM
