Old 04-11-2016, 12:00 PM
Last Online: 04-20-2016 06:02 AM
The crankshaft was running fine before, the rod and big end bearing are fine too so I'm reusing.
Crank bearings are new koyo C4 fit, I froze them and heated the case with a heat gun, and they dropped down all the way. I did the crank the same way on the right side case and it dropped all the way down. I torqued down pretty hard on both sides to ensure it is in all the way.
Thanks
Old 04-11-2016, 01:14 PM
Last Online: Today 10:01 AM
Thanks
If it were me I'd give the bearings a few taps to make sure they are fully seated and then try assembling again.
Old 02-11-2017, 02:46 PM
Last Online: 03-18-2017 07:14 AM
Default Oring
Hey guys my wiseco gasket set didn't come with the oring for water passage for the right case. Just the typical paper gasket between the left and right. Is the oring ommited ? Thanks guys
Old 02-13-2017, 02:24 PM
dogger315's Avatar
Last Online: 06-25-2019 10:27 PM
Apparently, it was omitted from your kit.
You'll still need that Oring. It's nothing special, just measure the diameter
of the cut out in the casting and buy a generic Oring that will fit.
Old 02-18-2017, 09:32 AM
Thanks dogger I ended up buying the oval ring that belongs in there. Another thing I got my cases together now the main shaft moves in and out about 2mm I assume that bushing and needle bearing will take up that slop when I install the clutch?
Old 02-21-2017, 10:09 AM
dogger315's Avatar
There should be a little play to allow for heat expansion, but 2mm is on the high side. Make sure you put all the washers, circlips and spacers in and in the correct orientation. Your engine will run with that much play, it just won't last that long with the main shaft moving around that much.
Similar Threads for: Round three 92-01 CR250 Engine build
Round two 92-01 CR250 engine build dogger315 Dirt Bike Restorations and Builds 28 10-16-2013 11:42 AM
92-01 CR250 Engine build dogger315 Dirt Bike Restorations and Builds 21 10-31-2012 03:12 PM
CR250 Engine Weight BadaPwned 2-Stroke Dirt Bike Forums 9 02-25-2009 08:06 PM
1999 cr250 engine help ctroger24 2-Stroke Dirt Bikes - Honda 3 11-29-2008 11:01 PM
CR250 engine noise RedRaider 2-Stroke Dirt Bikes - Honda 11 11-01-2007 12:19 AM
