Old 07-26-2012, 09:17 AM
dogger315's Avatar
Last Online: 06-25-2019 10:27 PM
i still have some engine noise. Is this normal???
Yes. These engines are by no means quiet when running. You have
straight cut gears, power valve actuator and a big ole' clutch basket
whirring around half in and half out of an oil bath - there's all kinds
of noise. It will diminish a little as the engine breaks in, but it will
always be there.
dogger
Old 07-26-2012, 11:56 AM
Last Online: 07-26-2013 10:56 AM
we did a rebuild on our 95 cr250,crank and bearings,it was our first time, we went of videos and post like these,we took our time and did every thing correct thanks to the guys who post this type of help, our cr runs great now
Old 07-26-2012, 04:33 PM
dogger315's Avatar
Outstanding, just made my day!
dogger
Old 07-30-2012, 08:06 AM
Last Online: 08-15-2012 05:02 AM
Thanks D
Made my year mate. Thanks for helping all our poor bast@rds. lol
Old 07-30-2012, 09:15 PM
dogger315's Avatar
Made my year mate
Thanks a bunch, HD!
Time to shred on that machine
Make me proud.
dogger
Old 08-14-2012, 02:48 AM
Hi D
When I took it out for a ride the first and second time it took it kinda slow. Low revs with cool down periods in between. One concern though.... It still throws out coolant at the overflow pipe. After about an hours ride on the dune i have to let it cool down and then i refill the radiator. It takes about 50ml of coolant everytime. There's no coolant leakage into the gearbox or through the inspection hole. Only out of the overflow. I have replaced my radiator cap already. The coolant that we buy here is a 30/70 mix. Could that make a difference.I have bought a 50/50 now. haven't tried it yet. We are planning to go out this weekend again, but I am still unsure if i can take longer trips with the coolant issue. I am very careful with the bike so it doesn't overheat. I made sure to check it every pit stop.
What's you r expert thoughts on this?
G
Old 08-14-2012, 09:28 AM
dogger315's Avatar
You don't need any antifreeze in your coolant. Antifreeze will cut
down on the effectiveness of your cooling system. Run distiiled
water mixed with a surfactant like Water Wetter for best results.
Another option is Engine Ice.
You can also try a higher pressure radiator cap. CV4 markets them.
Keep us posted.
dogger
Old 08-15-2012, 05:02 AM
Brilliant..... I did a bit of reading on Redline Water Wetter. Breaks down the surface tension of the water..... Absolutely brilliant. I've never heard of it but as I can see from the forums it does work. I have already replaced my radiator cap with a new highpressure one.
Cool man. Going to Saluki Motorsport tomorrow to buy some water wetter.
Thanks for the advise D.
Cheers mate.
Old 04-10-2016, 07:44 PM
Last Online: 04-20-2016 06:02 AM
Bringning back an old thread but it's revelant...
I'm putting back the engine together and whenI use the puller to pull the left case over the crank that is set in the right case, it binds up ans the crank won't spin. Anyone has ever had that issue?
Thanks!!
Old 04-11-2016, 08:50 AM
Last Online: Today 08:28 AM
Thanks!!
You'll need to make sure the bearings are fully seated for starters. Was your crankshaft rebuilt? If so they may not have gotten pressed back together correctly.
Similar Threads for: Round three 92-01 CR250 Engine build
Round two 92-01 CR250 engine build dogger315 Dirt Bike Restorations and Builds 28 10-16-2013 11:42 AM
92-01 CR250 Engine build dogger315 Dirt Bike Restorations and Builds 21 10-31-2012 03:12 PM
CR250 Engine Weight BadaPwned 2-Stroke Dirt Bike Forums 9 02-25-2009 08:06 PM
1999 cr250 engine help ctroger24 2-Stroke Dirt Bikes - Honda 3 11-29-2008 11:01 PM
CR250 engine noise RedRaider 2-Stroke Dirt Bikes - Honda 11 11-01-2007 12:19 AM
