Old 09-10-2010, 10:45 PM
moto x's Avatar
Last Online: 10-29-2011 07:56 PM
When done, spray the ignition components with WD40 or
MTTL and wipe off the excess. It's a good idea to clean, dry and coat the
ignition components after every ride. I leave the ignition cover off over night
to insure everything is dry. The stock plastic cover is next to worthless
when it comes to moisture.
should this be done if you dont have a plastic cover i installed a metal boyesen cover on my cr250
Old 09-11-2010, 09:40 AM
dogger315's Avatar
Last Online: 05-12-2019 06:25 PM
any chance you want to rebuild a yz250f motor?
Too many moving parts.
Good move, I use and recommend the alloy covers as well. They do
a good job of sealing up the ignition cavity, but it still doesn't hurt to
make the ignition cleaning/drying/coating a part of your post moto
maintenance.
dogger
Old 09-11-2010, 10:49 AM
char393's Avatar
cha cha
It was worth a try.
Looking forward to the next dogger-build installment.
Old 09-12-2010, 12:44 AM
moto x's Avatar
Thanks Dogger i'll keep it looked after maintance always comes 1st
Old 06-13-2012, 03:56 AM
Last Online: 08-15-2012 05:02 AM
Thanks Dogger
That was indeed the problem. In the meanwhile i sold the bike, bought it back from the same guy, rebuild the whole bike. Only thing i didn't do was replace the crank. Guess what broke! Seized big end. lol. I have disassembled the motor and had the old bearing pressed out by honda here in the UAE. they pressed the new ones in. Bob's your uncle.
Only one small problem. How do i remove the 2 small needle roller bearings on the clutch lifter lever. Do i need a blind bearing puller for this or will the come out quite easily. Ibought all the bearing for the sub assemble. ALL of 'em. So i do not want to leave anything old in there. It will make all my efforts seem sloppy if i leave those older bearings in there. Honda told me that it will be a mission to get themout, they have to basically break them apart to remove them. i cannot think that this wouldbe the case.
There must be an easier way.
Good job BTW.......
Old 06-13-2012, 06:53 AM
dogger315's Avatar
Honda told you right, those two are a PITB to remove. I've never had
consistent success removing them by heating the cases so one of the
reliable methods is a blind bearing puller. The problem there is they
are bunched together and it's hard to get a good grip with the tool.
Another method is to cut the cages with a Dremel and a carbide bit,
collapse them and remove. This has very obvious drawbacks if you
slip or go too far.
I know you don't want to leave old bearings in the engine, but you
might want to carefully look at and listen to those two as you rotate
the clutch actuator by hand. If you don't feel any drag or hear any
thing, I recommend you leave them. They are not what you would call
high wear items to start with.
Good luck with the build, sounds like you're becoming an old pro at it
already.
dogger
Old 06-13-2012, 06:49 PM
Last Online: 11-21-2018 08:13 PM
X2
leave em in. They are good for 20 years of hard use...........
Old 07-16-2012, 04:29 AM
readme Thanks for the help Dogegr and Sean
Thanx Dogger and Sean. I think i will leave them as is. I replaced the lifter lever. I will pack it with good quality grease and hope for the best. As you guys said, it's not a high wear item that's got drag on it all the time. So we should be fine.
Not gonna spend more money fixing stuff that isn't really necessary. My wife is already p'ed off as it is.
Thank for all your efforts and helping us with issues like theses. lol.
Check out the rebuild on my fb. Gerald Vorster | Facebook
See ya soon.
Old 07-17-2012, 09:29 AM
dogger315's Avatar
Sounds good D. You gotta choose your "battles" between the
wife and the dirt bikes. Just remember, happy wife, happy
home.
dogger
Old 07-25-2012, 11:05 PM
@ Dogger
Wife didn't kill me yet. I started the "Black Hole" up last night. after the complete top and bottome end rebuild. 3 Kicks. Pretty amazing. I was chuffed!
Needless to say after the rebuild i still have some engine noise. Is this normal??? I have replaced all the bearings, impeller, crank, the works.
I had a look at about 5 different youtube videos and the motors on there sound pretty similar to mine.
Your advise would be appreciated.
Similar Threads for: Round three 92-01 CR250 Engine build
Round two 92-01 CR250 engine build dogger315 Dirt Bike Restorations and Builds 28 10-16-2013 11:42 AM
92-01 CR250 Engine build dogger315 Dirt Bike Restorations and Builds 21 10-31-2012 03:12 PM
CR250 Engine Weight BadaPwned 2-Stroke Dirt Bike Forums 9 02-25-2009 08:06 PM
1999 cr250 engine help ctroger24 2-Stroke Dirt Bikes - Honda 3 11-29-2008 11:01 PM
CR250 engine noise RedRaider 2-Stroke Dirt Bikes - Honda 11 11-01-2007 12:19 AM
