Old 02-11-2020, 09:20 AM
Last Online: Yesterday 04:47 PM
Default Restoring rusted ignition components
Anyone got any tips or tricks for this? Needing to remove some rust/corrosion from the magnets in a flywheel as well as the metal portions of the coils on the stator that get the signal from the magnets. Pretty sure I have the stator portion figured out but the flywheel is proving more of a challenge.
Old 02-12-2020, 07:14 AM
Last Online: Yesterday 07:01 AM
Have you tried phosphoric acid? It gently eats away rust.
Old 02-12-2020, 09:32 AM
Nope, I haven't tried much of anything yet other than hitting it with some carb cleaner and a little scrubbing with some steel wool. I might try a Scotch Brite pad and see how that does; I'm sure the more crap I can get off those magnets the better off I'll be.
Old 02-12-2020, 09:30 PM
Big Maico 393's Avatar
Super Moderator
Last Online: 02-25-2020 09:05 PM
Go find a jug of evaporust & put then whole flywheel in it over night & then clean it off wiht a can of break clean.
Harbor fright or Home depot should have it in stock>
Old 02-13-2020, 09:54 AM
I'll have to look and see if I can find it, thanks Howard!
Similar Threads for: Restoring rusted ignition components
95 Cr 250 steel frame tubes rusted out watto Dirt Bike Restorations and Builds 2 12-26-2018 11:19 AM
Hinson Clutch Components Ryanl925 Product Reviews 3 12-07-2012 11:33 PM
Brake Components Rebuild dogger315 Dirt Bike Restorations and Builds 5 07-15-2012 02:13 PM
98 YZ125, questions (half new to mx). Needs 1k to run, rusted. DLo 2-Stroke Dirt Bikes - Yamaha 2 03-28-2004 07:34 AM
Rusted Bearings TexasDirtNap393 General Discussion 2 10-16-2003 10:24 PM
