Old 05-01-2015, 08:47 PM
Last Online: 05-12-2018 11:12 AM
Turns out a brand new head is the same cost as getting an old one refinished... if anyone wants the old on cheap...$15 plus shipping...let me know
New hat for the beast. [IMG][/IMG] [IMG][/IMG]
Old 05-04-2015, 07:15 PM
Last Online: 11-21-2018 08:13 PM
I'll take the old head, hit me at seanmx57@yahoo.com
Old 05-13-2015, 09:44 AM
Build update... got the carb cleaned and rejetted....picked up the brand new cylinder and new wiseco piston kit.
Tore the motor down further.....[IMG][/IMG]
---------- Post added at 08:35 AM ---------- Previous post was at 08:35 AM ----------
Sand on the impeller plate...
[IMG][/IMG]
---------- Post added at 08:42 AM ---------- Previous post was at 08:35 AM ----------
So im at a roadblock,... 1. Does anyone know how to get the impeller off as well as the bolts on the clutch without an impact air tool?
2. Does anyone have a case splitter they can let me rent for a few days?
---------- Post added at 08:44 AM ---------- Previous post was at 08:42 AM ----------
Oooh and Dogger,..when you received your new cylinder you remember there was a sort of yellow coating on the inside. Did you do anything to remove that before running the motor? Or just assemble it as is?
Old 05-13-2015, 10:58 AM
CRaSaurus's Avatar
Last Online: 01-02-2017 08:22 AM
I got my impeller off by inserting a cotton Shop rag in the exhaust port when the piston was down to lock the motor. I was relatively gentle but firm with a 1/4" ratchet.
The yellow coating is typically a wax or cosmolene (spelling), used to prevent rust. I would remove with mineral spirits or IPA or parts washer solvent. Then wash Very Thoroughly. When you think it is clean enough, test with a clean white paper towel wetted with red tranny fluid. If there is any sign of gray or dark color on the rag, it's not clean enough. On my V8 truck Motors I always clean with Hot Soapy water too. But that's Cast Iron.
Others??
Old 05-13-2015, 11:10 AM
Cool...though I already have the piston off...its just the rod sticking out. I tried putting the chain back on the counter and holding it with vice grips..but that didnt work.
Will clean up that cylinder
Old 05-13-2015, 11:17 AM
CRaSaurus's Avatar
Good Point, you even showed a picture. Sometimes I can be a little slow
Got a strap wrench? around the Clutch Basket.
Old 05-13-2015, 11:53 AM
Thats an idea,... I'll keep thinking on it. CR was it you i sent that seat cover to? Did you ever receive it?
Old 05-13-2015, 12:10 PM
CRaSaurus's Avatar
Yes I did. I think it came in Saturday or Monday. Looks great.
Meant to let you know. Just been swamped.
Old 05-13-2015, 01:03 PM
speedysvetz's Avatar
Last Online: 04-01-2019 02:37 PM
I've never seen the slanted spark plug hole on a two stroke head. Thats probably pretty convenient for changing out plugs. Haven't seen a head with two coolant inlets either; is that a 500 thing?
Old 05-13-2015, 05:12 PM
Cool CR... Yea man...The beast has its own special design.
Similar Threads for: 91 cr500/ 07 crf450 build to Cr 500AF
CR500 Engine Build Part 6 dogger315 Dirt Bike Restorations and Builds 24 09-20-2015 12:14 PM
Compilation- dogger315's Honda CR500 AF build cowboyona426 Dirt Bike Restorations and Builds 0 12-19-2014 11:27 AM
CR500 Engine Build Pictorial Part 2 dogger315 Dirt Bike Restorations and Builds 15 02-01-2013 11:24 PM
CR500 Engine build Pictorial Part 3 dogger315 Dirt Bike Restorations and Builds 7 09-18-2010 03:14 PM
CR500 Engine Build Pictorial Part 1 dogger315 Dirt Bike Restorations and Builds 18 09-10-2010 11:56 AM
